メインコンテンツにスキップ
How to Fix a Loose Connector in an Anivia 1080p Webcam
必要な工具と部品
  1. How to Fix a Loose Connector in an Anivia 1080p Webcam, How to Fix a Loose Connector in an Anivia 1080p Webcam: 手順 1、 3の画像 1 How to Fix a Loose Connector in an Anivia 1080p Webcam, How to Fix a Loose Connector in an Anivia 1080p Webcam: 手順 1、 3の画像 2 How to Fix a Loose Connector in an Anivia 1080p Webcam, How to Fix a Loose Connector in an Anivia 1080p Webcam: 手順 1、 3の画像 3
    • Pry open the face plate of the webcam using the iFixit opening pick or another safe tool, and set it aside.
  2. How to Fix a Loose Connector in an Anivia 1080p Webcam: 手順 2、 3の画像 1 How to Fix a Loose Connector in an Anivia 1080p Webcam: 手順 2、 3の画像 2 How to Fix a Loose Connector in an Anivia 1080p Webcam: 手順 2、 3の画像 3
    • Remove the three main screws using a Phillips screwdriver while carefully holding the camera motherboard in place.
  3. How to Fix a Loose Connector in an Anivia 1080p Webcam: 手順 3、 3の画像 1 How to Fix a Loose Connector in an Anivia 1080p Webcam: 手順 3、 3の画像 2 How to Fix a Loose Connector in an Anivia 1080p Webcam: 手順 3、 3の画像 3
    • Remove the camera and motherboard from the casing carefully.
  4. How to Fix a Loose Connector in an Anivia 1080p Webcam: 手順 4、 3の画像 1 How to Fix a Loose Connector in an Anivia 1080p Webcam: 手順 4、 3の画像 2 How to Fix a Loose Connector in an Anivia 1080p Webcam: 手順 4、 3の画像 3
    • Detach the cable from the connecter on the motherboard.
    • Pull from the plastic as to not damage any of the wires.
  5. How to Fix a Loose Connector in an Anivia 1080p Webcam: 手順 5、 3の画像 1 How to Fix a Loose Connector in an Anivia 1080p Webcam: 手順 5、 3の画像 2 How to Fix a Loose Connector in an Anivia 1080p Webcam: 手順 5、 3の画像 3
    • Identify where the connector is loose and solder the piece back into place.
    • Use only as little solder as needed to keep functionality in tact.
    • Caution: The soldering iron is hot and should be handled with care.
  6. How to Fix a Loose Connector in an Anivia 1080p Webcam: 手順 6、 2の画像 1 How to Fix a Loose Connector in an Anivia 1080p Webcam: 手順 6、 2の画像 2
    • Reattach the cable to the connector.
  7. How to Fix a Loose Connector in an Anivia 1080p Webcam: 手順 7、 2の画像 1 How to Fix a Loose Connector in an Anivia 1080p Webcam: 手順 7、 2の画像 2
    • Place the motherboard and camera back into the casing.
  8. How to Fix a Loose Connector in an Anivia 1080p Webcam: 手順 8、 3の画像 1 How to Fix a Loose Connector in an Anivia 1080p Webcam: 手順 8、 3の画像 2 How to Fix a Loose Connector in an Anivia 1080p Webcam: 手順 8、 3の画像 3
    • Screw the camera and motherboard back into place.
  9. How to Fix a Loose Connector in an Anivia 1080p Webcam: 手順 9、 3の画像 1 How to Fix a Loose Connector in an Anivia 1080p Webcam: 手順 9、 3の画像 2 How to Fix a Loose Connector in an Anivia 1080p Webcam: 手順 9、 3の画像 3
    • Snap the faceplate covering back into place.
ゴール
作成者
2人の作成者と共同で作成されました。
Duncan Holloway
メンバー登録日: 02/24/21
169 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S1-G21, Raign Spring 2021 University of North Texas, Team S1-G21, Raign Spring 2021人のメンバー
UNT-RAIGN-S21S1G21
2 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 17
過去 30 日: 54
今までの合計 879
