メインコンテンツにスキップ
How to Fix a Loose Connection on a Power Strip
必要な工具と部品
  1. How to Fix a Loose Connection on a Power Strip, How to Fix a Loose Connection on a Power Strip: 手順 1、 1の画像 1
    • Before you start, make sure you unplug the power strip from the wall! It is very important, as you will get an electric shock if you do not do so.
    • Take out all the plugs on the power strip.
  2. How to Fix a Loose Connection on a Power Strip: 手順 2、 2の画像 1 How to Fix a Loose Connection on a Power Strip: 手順 2、 2の画像 2
    • Flip over the power strip.
    • Use a Phillips #0 screwdriver to take out the 6 mm screws on the back of the power strip.
  3. How to Fix a Loose Connection on a Power Strip: 手順 3、 2の画像 1 How to Fix a Loose Connection on a Power Strip: 手順 3、 2の画像 2
    • Separate the outer shell from the power strip.
    • Most of the outer shells can be separated out very easily after the screws are taken out.
  4. How to Fix a Loose Connection on a Power Strip: 手順 4、 2の画像 1 How to Fix a Loose Connection on a Power Strip: 手順 4、 2の画像 2
    • Locate two pairs of copper sheets for each socket.
  5. How to Fix a Loose Connection on a Power Strip: 手順 5、 3の画像 1 How to Fix a Loose Connection on a Power Strip: 手順 5、 3の画像 2 How to Fix a Loose Connection on a Power Strip: 手順 5、 3の画像 3
    • Use a screwdriver to push the two copper sheets closer to each other. Do this on all the pairs of copper sheets without a solid connection.
  6. How to Fix a Loose Connection on a Power Strip: 手順 6、 2の画像 1 How to Fix a Loose Connection on a Power Strip: 手順 6、 2の画像 2
    • Install the outer shell back to the power strip.
    • Put the outer shell on it and press it to install.
  7. How to Fix a Loose Connection on a Power Strip: 手順 7、 2の画像 1 How to Fix a Loose Connection on a Power Strip: 手順 7、 2の画像 2
    • Flip over the power strip, and then use screwdriver to install all the screws back.
  8. How to Fix a Loose Connection on a Power Strip: 手順 8、 1の画像 1
    • Plug the power strip into the wall socket, and then plug electric machine to the power strip to test that if the connection of power strip has improved.
終わりに
You’re all done!
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Xike Cao
メンバー登録日: 09/19/21
210 ポイント
1ガイドが承認済み
チーム
York University, Team F-27, Woodhouse Fall 2021 York University, Team F-27, Woodhouse Fall 2021人のメンバー
YORK-WOODHOUSE-F21SFG27
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 29
過去 30 日: 84
今までの合計 1,312
