メインコンテンツにスキップ
How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock
必要な工具と部品
  1. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock, How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: 手順 1、 2の画像 1 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock, How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: 手順 1、 2の画像 2
    • Make sure the lock is in the unlock position when you start.
    • Use a Philips #1 screwdriver to remove the two 8 mm screws from the left and right sides of the lock.
  2. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: 手順 2、 3の画像 1 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: 手順 2、 3の画像 2 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: 手順 2、 3の画像 3
    • Lift the faceplate from the lock.
    • Locate the battery pack stationed at the top of the lock and the programming button at the center of the lock.
  3. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: 手順 3、 1の画像 1
    • Pull the battery pack up and off to remove it from the lock housing.
  4. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: 手順 4、 2の画像 1 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: 手順 4、 2の画像 2
    • Re-insert the battery pack while holding down the programming button.
    • Ensure the battery pack is fully inserted by pushing it down.
  5. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: 手順 5、 3の画像 1 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: 手順 5、 3の画像 2 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: 手順 5、 3の画像 3
    • Release the programming button after the indicator light turns red then green.
    • Repeat steps 3 through 5 if the light does not turn green.
  6. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: 手順 6、 2の画像 1 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: 手順 6、 2の画像 2
    • Press the program button again to allow the Smartlock to re-calibrate and reprogram itself.
    • The lock will lock and unlock a few times to calibrate and will remain in the lock position when the calibration is complete.
  7. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: 手順 7、 3の画像 1 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: 手順 7、 3の画像 2 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: 手順 7、 3の画像 3
    • To reassemble your lock, reseat the faceplate on the lock.
    • Twist the lock switch until it aligns with the bolt mechanism and the faceplate sits flush against the lock.
    • Use the Phillips #1 screwdriver to secure the two 8 mm screws back into place to conclude the fix.
終わりに
Your lock will not jam anymore!
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Manpreet Sahota
メンバー登録日: 09/09/21
145 ポイント
1ガイドが承認済み
チーム
York University, Team 1-21, O'Regan Fall 2021 York University, Team 1-21, O'Regan Fall 2021人のメンバー
YORK-O'REGAN-F21S1G21
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 14
過去 7 日: 92
過去 30 日: 360
今までの合計 14,545
