メインコンテンツにスキップ
How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line
必要な工具と部品
  1. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line, How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 手順 1、 1の画像 1
    • Move the dial to a vertical position to close the fuel line.
    • This will prevent fluids from continuing to move freely throughout the lawnmower.
  2. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 手順 2、 3の画像 1 How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 手順 2、 3の画像 2 How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 手順 2、 3の画像 3
    • Use the screwdriver to push the right tension pin to the right so the hose can be removed.
    • Remove the right hose by wiggling the screwdriver between the hose and the tube where it is attached.
    • Have the empty bottle ready to use as soon as the hose is detached from the fuel line.
  3. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 手順 3、 1の画像 1
    • Place the hose into a bottle to catch the leaking fluid from the fuel tank.
    • More liquid will be released from the right hose than in any other part of the process.
  4. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 手順 4、 3の画像 1 How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 手順 4、 3の画像 2 How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 手順 4、 3の画像 3
    • Move the tension pin to the left to allow the hose to be removed.
    • Remove the left hose and catch the fluids that leak out.
  5. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 手順 5、 2の画像 1 How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 手順 5、 2の画像 2
    • Remove the 10 mm bolt holding the carburetor fuel cup in place.
    • Remove the carburetor fuel cup
    • Use the rag to clean the inside of the carburetor fuel cup after it has been removed.
    • Let any fluid released from removing the carburetor spill onto the rag.
  6. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 手順 6、 1の画像 1
    • Tilt the lawnmower forward so any remaining fluids can make their way out.
  7. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 手順 7、 1の画像 1
    • Place the detached hoses back to the fuel line.
    • Move the pins back to the end of the hose to hold them in place.
  8. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 手順 8、 1の画像 1
    • Use the fuel can to refill the lawnmower now that the contaminated fuel has been removed.
  9. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 手順 9、 1の画像 1
    • Turn the dial to a horizontal position to reopen the fuel line.
終わりに
With the water out of the fuel line, the lawnmower should be ready for use.
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Alonso Pantoja
メンバー登録日: 01/24/22
223 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 6-10, Briggs Spring 2022 CSU Los Angeles, Team 6-10, Briggs Spring 2022人のメンバー
CSULA-BRIGGS-S22S6G10
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 20
過去 30 日: 102
今までの合計 1,813
