メインコンテンツにスキップ
How to Fix a Hole in Leggings by Hand Sewing
必要な工具と部品
  1. How to Fix a Hole in Leggings by Hand Sewing, How to Fix a Hole in Leggings by Hand Sewing: 手順 1、 3の画像 1 How to Fix a Hole in Leggings by Hand Sewing, How to Fix a Hole in Leggings by Hand Sewing: 手順 1、 3の画像 2 How to Fix a Hole in Leggings by Hand Sewing, How to Fix a Hole in Leggings by Hand Sewing: 手順 1、 3の画像 3
    • Use scissors to cut a piece of thread that is the color of your leggings at least 12 inches long.
  2. How to Fix a Hole in Leggings by Hand Sewing: 手順 2、 1の画像 1
    • Mishandling of the needle could result in minor or moderate injury.
    • Thread the needle by running the piece of thread through the eye, or opening, of the needle.
  3. How to Fix a Hole in Leggings by Hand Sewing: 手順 3、 1の画像 1
    • Pull the thread through the needle until there are two equal halves of thread.
    • Tie a knot with the ends of the thread.
  4. How to Fix a Hole in Leggings by Hand Sewing: 手順 4、 1の画像 1
    • Turn the leggings inside out.
    • This is so the sewing will be on the inside of the leggings.
  5. How to Fix a Hole in Leggings by Hand Sewing: 手順 5、 1の画像 1
    • Smooth out the fabric around the hole.
  6. How to Fix a Hole in Leggings by Hand Sewing: 手順 6、 1の画像 1
    • Pinch the fabric together.
    • Begin your stitch on one end of the hole.
  7. How to Fix a Hole in Leggings by Hand Sewing: 手順 7、 1の画像 1
    • Use short stitches so that the thread will not break easily.
    • Make sure the hole is completely included in the stitches.
  8. How to Fix a Hole in Leggings by Hand Sewing: 手順 8、 1の画像 1
    • Tie a knot using the tied ends of the thread (at the beginning of the hole) and the thread still attached to the needle (at the end of the hole).
    • Make sure the knot is large enough so it doesn't slip through the stitches.
  9. How to Fix a Hole in Leggings by Hand Sewing: 手順 9、 1の画像 1
    • Cut the loose thread above the new knot with scissors.
ゴール
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Emily Coleman
メンバー登録日: 09/17/20
223 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team S3-G4, Willis Fall 2020 University of Memphis, Team S3-G4, Willis Fall 2020人のメンバー
UM-WILLIS-F20S3G4
1 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 36
過去 7 日: 227
過去 30 日: 1,103
今までの合計 40,930
