メインコンテンツにスキップ
How to Fix a Faulty Button on a Mayflash F300
必要な工具と部品
  1. How to Fix a Faulty Button on a Mayflash F300, How to Fix a Faulty Button on a Mayflash F300: 手順 1、 2の画像 1 How to Fix a Faulty Button on a Mayflash F300, How to Fix a Faulty Button on a Mayflash F300: 手順 1、 2の画像 2
    • Flip around the Mayflash F300, so that the metal panel is facing you.
    • It may be helpful to place the device on a box if you cannot hold it, as the joystick would otherwise be under pressure.
  2. How to Fix a Faulty Button on a Mayflash F300: 手順 2、 3の画像 1 How to Fix a Faulty Button on a Mayflash F300: 手順 2、 3の画像 2 How to Fix a Faulty Button on a Mayflash F300: 手順 2、 3の画像 3
    • Unscrew the six 9 mm Phillips #00 screws that hold together the metal panel.
    • Gently pry the panel away once it is unscrewed.
  3. How to Fix a Faulty Button on a Mayflash F300: 手順 3、 2の画像 1 How to Fix a Faulty Button on a Mayflash F300: 手順 3、 2の画像 2
    • Unplug the two cables going into the button you wish to clean or replace.
    • These two cables can be quite stubborn to remove, so gently wiggling them as you pull will make it easier.
  4. How to Fix a Faulty Button on a Mayflash F300: 手順 4、 1の画像 1
    • Squeeze the two tabs that are on either side of the button and push it out.
  5. How to Fix a Faulty Button on a Mayflash F300: 手順 5、 1の画像 1
    • Grab your toothbrush and clean out all the dirt you may find inside and around the button.
    • Alternatively, if you wish to install an entirely new button, you can simply set aside the old one.
  6. How to Fix a Faulty Button on a Mayflash F300: 手順 6、 2の画像 1 How to Fix a Faulty Button on a Mayflash F300: 手順 6、 2の画像 2
    • With your button now clean and ready to go, place it in the empty slot and push it back down. Make sure it snaps in place.
  7. How to Fix a Faulty Button on a Mayflash F300: 手順 7、 1の画像 1
    • Reconnect the two cables to the button.
  8. How to Fix a Faulty Button on a Mayflash F300: 手順 8、 1の画像 1
    • Take the back panel of the arcade stick and screw it back in place.
終わりに
Hopefully these steps were clear and useful to you! Happy gaming!
作成者
1人の作成者と共同作成されました。
Ali Fareed
メンバー登録日: 01/09/24
157 ポイント
1ガイドが承認済み
チーム
York University, Team P-99, O'Regan Winter 2024 York University, Team P-99, O'Regan Winter 2024人のメンバー
YORK-O'REGAN-W24SPG99
1 メンバー
1のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 31
今までの合計 647
