メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How to Fix a Dress Strap With a Clasp
必要な工具と部品
    1. How to Fix a Dress Strap With a Clasp, How to Fix a Dress Strap With a Clasp: 手順 1、 3の画像 1 How to Fix a Dress Strap With a Clasp, How to Fix a Dress Strap With a Clasp: 手順 1、 3の画像 2 How to Fix a Dress Strap With a Clasp, How to Fix a Dress Strap With a Clasp: 手順 1、 3の画像 3
      • Pull the end of the strap through the loop on the collar of the dress.
      • Locate the buckle along the length of the strap and feed the end of the strap under the opening of the buckle (closest to the strap).
      • Continue feeding the strap through the next opening of the buckle.
      FixBotに聞いてみる
      コメントを追加
    2. How to Fix a Dress Strap With a Clasp: 手順 2、 3の画像 1 How to Fix a Dress Strap With a Clasp: 手順 2、 3の画像 2 How to Fix a Dress Strap With a Clasp: 手順 2、 3の画像 3
      • Roll the end of the strap 1/8".
      • Roll it one more time.
      • Compare the newly made loop to the other functioning strap to ensure the loops are the same length.
      FixBotに聞いてみる
      コメントを追加
    3. How to Fix a Dress Strap With a Clasp: 手順 3、 1の画像 1
      • Secure the fold with the needle and thread.
      • Never use any part of your hand to brace the material as you push the needle through it, to avoid minor injuries.
      • For instructions on how to thread a needle, follow this tutorial: How to thread a needle.
      FixBotに聞いてみる
      コメントを追加
    4. How to Fix a Dress Strap With a Clasp: 手順 4、 2の画像 1 How to Fix a Dress Strap With a Clasp: 手順 4、 2の画像 2
      • Poke the needle through to one edge of the looped strap to begin securing the fold to the strap.
      • Begin sewing along the width of the strap, using a short stitch length (2.0 mm).
      FixBotに聞いてみる
      コメントを追加
    5. How to Fix a Dress Strap With a Clasp: 手順 5、 3の画像 1 How to Fix a Dress Strap With a Clasp: 手順 5、 3の画像 2 How to Fix a Dress Strap With a Clasp: 手順 5、 3の画像 3
      • To finish securing the fabric together, create a loop with the excess thread attached to the needle.
      • Use a quilter's knot to finish securing the fabric.
      • For more detail on performing a quilters knot, follow this link: Quilters Knot.
      FixBotに聞いてみる
      コメントを追加
    6. How to Fix a Dress Strap With a Clasp: 手順 6、 2の画像 1 How to Fix a Dress Strap With a Clasp: 手順 6、 2の画像 2
      • Pull the knot tightly.
      • Cut the excess thread with the scissors.
      FixBotに聞いてみる
      コメントを追加
ゴール
キャンセル: このガイドを終了できませんでした。
作成者
1人の作成者と共同作成されました。
Luke Bartels
メンバー登録日: 01/19/26
133 ポイント
1ガイドが承認済み
チーム
Northern Arizona University, Team 1-2, Konrad Spring 2026 Northern Arizona University, Team 1-2, Konrad Spring 2026人のメンバー
NAU-KONRAD-S26S1G2
4 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 58
過去 30 日: 174
今までの合計 662
