メインコンテンツにスキップ
How to Fix a Dirty Censor in a Corsair Harpoon RGB
必要な工具と部品
  1. How to Fix a Dirty Censor in a Corsair Harpoon RGB, How to Fix a Dirty Censor in a Corsair Harpoon RGB: 手順 1、 2の画像 1 How to Fix a Dirty Censor in a Corsair Harpoon RGB, How to Fix a Dirty Censor in a Corsair Harpoon RGB: 手順 1、 2の画像 2
    • Start by flipping the mouse over to view the flat side of the mouse.
    • Remove the mouse feet to reveal the screws holding the bottom and top part of the mouse together.
  2. How to Fix a Dirty Censor in a Corsair Harpoon RGB: 手順 2、 3の画像 1 How to Fix a Dirty Censor in a Corsair Harpoon RGB: 手順 2、 3の画像 2 How to Fix a Dirty Censor in a Corsair Harpoon RGB: 手順 2、 3の画像 3
    • Use a Phillips #0 screwdriver to remove the screws that hold the mouse together.
    • Once the screws are removed, pull the mouse apart by holding the top and bottom pieces.
    • The mouse will be pulled into two pieces: the top (rounded part) and bottom (flat part).
  3. How to Fix a Dirty Censor in a Corsair Harpoon RGB: 手順 3、 1の画像 1
    • After the mouse has been pulled apart, the flex cable will be visible. This must be removed before continuing.
    • To remove the flex cable, gently pull the cable clip until it becomes unlatched.
  4. How to Fix a Dirty Censor in a Corsair Harpoon RGB: 手順 4、 2の画像 1 How to Fix a Dirty Censor in a Corsair Harpoon RGB: 手順 4、 2の画像 2
    • Remove the motherboard. The motherboard is mounted on the mouse, so gently remove by simply pulling the motherboard from within the mouse.
  5. How to Fix a Dirty Censor in a Corsair Harpoon RGB: 手順 5、 2の画像 1 How to Fix a Dirty Censor in a Corsair Harpoon RGB: 手順 5、 2の画像 2
    • Once the motherboard is removed, the optical sensor will be fully exposed. This is the piece that is causing the lag in the mouse.
    • The optical sensor is dirty, and needs to be gently cleaned with a Q-tip or soft cloth dipped in 90% isopropyl alcohol.
終わりに
To disassemble, clean, and reassemble your mouse, follow these guidelines.
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Kady Volmering
メンバー登録日: 03/16/21
200 ポイント
1ガイドが承認済み
チーム
2 件のコメント
Muy buena guia. Me fue muy util. Gracias y saludos.
Bolzano - 返信
why did you opened it if you just cleaned eye with alcohol
antoncoinz - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 31
過去 30 日: 125
今までの合計 6,309
