メインコンテンツにスキップ
How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard
必要な工具と部品
  1. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard, How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: 手順 1、 3の画像 1 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard, How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: 手順 1、 3の画像 2 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard, How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: 手順 1、 3の画像 3
    • Unplug the cord from the wall and the back of the keyboard.
  2. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: 手順 2、 3の画像 1 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: 手順 2、 3の画像 2 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: 手順 2、 3の画像 3
    • Flip over the keyboard.
    • Check the battery holder and remove the battery cover.
    • Remove all outer screws with a Philips screwdriver. These are the 19.0 mm Philips screws.
    • Remove the middle screw and the middle top screw. They are the 25.4 mm Philips screws.
  3. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: 手順 3、 1の画像 1
    • Carefully remove the cover, and set it aside.
    • Find the contact pad.
  4. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: 手順 4、 3の画像 1 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: 手順 4、 3の画像 2 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: 手順 4、 3の画像 3
    • At the top of the contact pad, carefully pinch the black clamps closed.
    • Once all the clamps are closed, wiggle the contact pad free.
    • Be careful of the small black hooks at the bottom.
  5. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: 手順 5、 1の画像 1
    • After the contact pad is free, gently lift it up.
  6. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: 手順 6、 3の画像 1 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: 手順 6、 3の画像 2 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: 手順 6、 3の画像 3
    • Vacuum and/or gently wipe the dust away.
  7. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: 手順 7、 1の画像 1
    • Place the contact pad back gently.
  8. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: 手順 8、 1の画像 1
    • Place the cover back on.
    • Place the screws back in.
    • The 25.4mm Philips screws go in the middle and top middle. The 19mm screws go around the case.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Sydney Schuett
メンバー登録日: 07/20/20
211 ポイント
1ガイドが承認済み
チーム
UW Tacoma, Team S1-G14, Cardinal Summer 2020 UW Tacoma, Team S1-G14, Cardinal Summer 2020人のメンバー
UWT-CARDINAL-SU20S1G14
1 メンバー
1のガイドは作成済み
コメント 1 件
This is a good pictorial guide to how the keyboard works and how to service it, I used electronic switch cleaner {aerosol} on a cloth to clean the contacts and it was successful leaving all the keys working.
jeff may - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 47
今までの合計 2,929
