はじめに
Quick repair for crookedly hanging cabinet doors—with just ONE tool! (Perfect for VINTAGE homes)
必要な工具と部品
Examine which door needs to be adjusted and to what extent. In this example, we start the adjustment with the lower screws of the cabinet door.
Hold onto the cabinet as you unscrew the two bottom screws to reposition it.
Select the appropriate screwdriver bit.
Tighten the screws to adjust appropriately.
The gap should be even from top to bottom. Ensure that it is and hold the cabinet in place to adjust if it is not.
You've done it! As long as the gap is even, your results should be just like this.
Great job!
5 の人々がこのガイドを完成させました。
