メインコンテンツにスキップ
How to Fix a Cracked Lady Zest Q Nasal CPAP Mask with Headgear
必要な工具と部品
  1. How to Fix a Cracked Lady Zest Q Nasal CPAP Mask with Headgear, How to Fix a Cracked Lady Zest Q Nasal CPAP Mask with Headgear: 手順 1、 2の画像 1 How to Fix a Cracked Lady Zest Q Nasal CPAP Mask with Headgear, How to Fix a Cracked Lady Zest Q Nasal CPAP Mask with Headgear: 手順 1、 2の画像 2
    • Trim the edges of the fiberglass sheet into small strips that cover the crack on the mask.
    • The trimmed fiberglass strands should look like this! (second picture)
  2. How to Fix a Cracked Lady Zest Q Nasal CPAP Mask with Headgear: 手順 2、 1の画像 1
    • Proceed to push the resin and sealant out into a container to mix.
    • Use latex gloves to protect your hands from the resin.
  3. How to Fix a Cracked Lady Zest Q Nasal CPAP Mask with Headgear: 手順 3、 2の画像 1 How to Fix a Cracked Lady Zest Q Nasal CPAP Mask with Headgear: 手順 3、 2の画像 2
    • Begin to mix the resin and the sealant together using the toothpicks.
  4. How to Fix a Cracked Lady Zest Q Nasal CPAP Mask with Headgear: 手順 4、 1の画像 1
    • Mix in some of the fiberglass strands into the resin until the strands are fully saturated with resin.
    • Scoop up some of the resin and fiberglass mixture with the toothpick.
  5. How to Fix a Cracked Lady Zest Q Nasal CPAP Mask with Headgear: 手順 5、 2の画像 1 How to Fix a Cracked Lady Zest Q Nasal CPAP Mask with Headgear: 手順 5、 2の画像 2
    • Apply the fiber glass and resin combo onto the crack and, using another toothpick, arrange the fiberglass to cover the crack.
    • Repeat until the hole has been sufficiently covered.
  6. How to Fix a Cracked Lady Zest Q Nasal CPAP Mask with Headgear: 手順 6、 1の画像 1
    • Let the resin dry.
    • The time will vary based on the resin, amount of solvent used, and weather conditions, so be sure to read the back of your resin container to estimate how long it will take to dry.
  7. How to Fix a Cracked Lady Zest Q Nasal CPAP Mask with Headgear: 手順 7、 1の画像 1
    • When you are done the final product should be covering the crack and completely airtight.
    • Check the mask to ensure that the crack is fully sealed.
    • If there is still pressure loss through the crack, apply more resin to the crack until it is sealed.
終わりに
作成者
1人の作成者と共同作成されました。
Spencer Anderson
メンバー登録日: 01/15/21
145 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 6
今までの合計 137
