メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
This Fast Fix can be used to patch a crack in any hollow wood door. The materials that will need to be purchased include body/wood filler, sandpaper/sanding sponge, paint, putty knife, and a paint brush. To prevent any hazards, gloves and a face mask are recommended. Overall, this Fast fix should take no longer than an hour to complete and should not cost over $10 when purchasing the required materials.
  1. Clean and dust the affected area with a paper towel, rag, or brush. Clean and dust the affected area with a paper towel, rag, or brush.
    • Clean and dust the affected area with a paper towel, rag, or brush.
  2. Sand the affected area with a 60/80 grit sanding sponge.
    • Sand the affected area with a 60/80 grit sanding sponge.
    • Any type of sand paper or sanding sponge will work on wood surfaces.
    • It is recommended to place newspaper under the door to keep the sand/dust contained.
  3. Remove any sand/dust with a paper towel.
    • Remove any sand/dust with a paper towel.
    • It is recommend to use gloves to prevent any minor splinters.
    • It is also recommended to use a face mask to prevent inhaling any dust/sand.
  4. iPhone LCDスクリーン修理キット
    生涯保証付きの低コストオプション
    キット商品を見る
    品質ではなく、修理コストを削減しましょう。
    キット商品を見る
  5. Use putty knife to apply body filler until an even layer is formed.
    • Use putty knife to apply body filler until an even layer is formed.
    • Start with a small amount and then add more if needed.
    • A smaller putty knife allows for easier application in creases and folds.
  6. Remove any excess body filler with putty knife
    • Remove any excess body filler with putty knife
    • Its okay if the surface is uneven, you will use sandpaper to smooth the surface in a later step.
  7. Allow to dry (or use a blow dryer for lesser wait time).
    • Allow to dry (or use a blow dryer for lesser wait time).
    • More expensive brands of body filler will dry faster.
  8. Gently sand the surface. Gloves and a face mask are highly recommended but not required for this step.
    • Gently sand the surface.
    • Gloves and a face mask are highly recommended but not required for this step.
    • Newspaper is also recommended to contain any sand/dust.
    • Reapply body filler, allow to dry, and re-sand if surface remains uneven.
  9. Use a similar toned paint to paint the area if any discoloration exists.
    • Use a similar toned paint to paint the area if any discoloration exists.
    • Wood paint is ideal for wood doors.
  10. Allow to dry.
    • Allow to dry.
    • Your door should now look neutral and clean.
    • A blow dryer is recommended for faster drying.
終わりに
Lea Thomas
メンバー登録日: 2019年01月20日
169 ポイント
1ガイドが承認済み
チーム
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2019 USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2019人のメンバー
USFSM-STEWART-S19S1G1
18 メンバー
13のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 71
過去 7 日: 498
過去 30 日: 2,008
今までの合計 8,782
