メインコンテンツにスキップ
How to Fix a Broken XLR Microphone Cable
必要な工具と部品
  1. How to Fix a Broken XLR Microphone Cable, How to Fix a Broken XLR Microphone Cable: 手順 1、 3の画像 1 How to Fix a Broken XLR Microphone Cable, How to Fix a Broken XLR Microphone Cable: 手順 1、 3の画像 2 How to Fix a Broken XLR Microphone Cable, How to Fix a Broken XLR Microphone Cable: 手順 1、 3の画像 3
    • This guide will utilize a soldering iron. Please use a heat-resistant surface and proceed with caution.
    • Place the end of the XLR Cable on a clean, uncluttered surface.
    • Using a small screwdriver, unscrew the single screw near the top of the cable.
    • Gently pull apart the exterior metal from the internal mechanism.
  2. How to Fix a Broken XLR Microphone Cable: 手順 2、 1の画像 1
    • Assess which connections have fallen loose. In this instance, the white cable is disconnected.
  3. How to Fix a Broken XLR Microphone Cable: 手順 3、 2の画像 1 How to Fix a Broken XLR Microphone Cable: 手順 3、 2の画像 2
    • Assess whether or not there's enough exposed wire to reconnect loose cables. In this instance, the exposed cables are too short to effectively reconnect.
    • If the exposed wires are too short, use wire strippers or a razor to cut back the insulation.
    • Separate the wires.
  4. How to Fix a Broken XLR Microphone Cable: 手順 4、 3の画像 1 How to Fix a Broken XLR Microphone Cable: 手順 4、 3の画像 2 How to Fix a Broken XLR Microphone Cable: 手順 4、 3の画像 3
    • Soldering irons are extremely hot. Proceed with extreme caution.
    • Solder each of the loose wires to the coinciding metal prong.
    • For more information on effectively soldering wire, please visit iFixit's Soldering Guide.
    • If necessary, use a thin wire to further manipulate the connection.
  5. How to Fix a Broken XLR Microphone Cable: 手順 5、 2の画像 1 How to Fix a Broken XLR Microphone Cable: 手順 5、 2の画像 2
    • When the soldering is complete, reconnect the metal exterior to the head of the cable.
    • Using a small screwdriver, reattach the single screw.
終わりに
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Abbie Zajac
メンバー登録日: 01/19/16
203 ポイント
1ガイドが承認済み
チーム
Oakland University, Team 6-3, Walwema Winter 2016 Oakland University, Team 6-3, Walwema Winter 2016人のメンバー
OAK-WALWEMA-W16S6G3
2 メンバー
2のガイドは作成済み
コメント 1 件
Great repair. If the cabke is broken I have a video on resolving that issue. https://youtu.be/E8CiX4cnc-U
DIM Tips - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 21
過去 30 日: 141
今までの合計 24,873
