はじめに
Wooden frames and mirrors are often broken then tossed into the garbage where they slowly deteriorate over time. This has negative effects on the globe. With this guide, you can repair your cracked wooden framed mirror with wood glue and ratchet straps. Instructions for securing it to the wall are also included, an anchoring kit can be purchased from your local hardware store.
必要な工具と部品
Place the plastic sheet on the ground. Place ratchet straps on the sheeting. Lay the frame face down on top of the plastic sheeting. Dust off the area that is damaged.
Add glue to the crack.
Once both of the loops have been tightly screwed in, get an approximation of how much wire you will be using.
Put the wire through the loop with about 6" excess.
Place the anchors for the wall a few inches above the screws and slightly centered.
Pull taut on the wire where the anchors are and put the opposite end of the wire through the loop.
Feed the short end through the loop on the left side of the interior wire and pull tight.
Feed the short end through the loop but this time on the right side of the interior wire and pull tight. You are creating a slipknot.
Once the slipknot is tight, spin the excess wire around the interior wire like a coil for 1/2". Remove any excess with wire cutters.
To unhook the mirror from the wall, follow these steps in reverse.
2 の人々がこのガイドを完成させました。
