メインコンテンツにスキップ
How to Fix a Broken Toilet Paper Holder
必要な工具と部品
  1. How to Fix a Broken Toilet Paper Holder, How to Fix a Broken Toilet Paper Holder: 手順 1、 1の画像 1
    • As you can tell, the left holder is loose. Replacing the anchor is much needed.
  2. How to Fix a Broken Toilet Paper Holder: 手順 2、 1の画像 1
    • Remove the Allen screw under each holder.
    • I used a 1/6" Allen bit because that is what fit my toilet paper holder's Allen screw. Use the bit according to the screw available.
    • If the screw size is unknown, I would recommend buying a pack with several Allen bits and trying each until the right one is found.
  3. How to Fix a Broken Toilet Paper Holder: 手順 3、 3の画像 1 How to Fix a Broken Toilet Paper Holder: 手順 3、 3の画像 2 How to Fix a Broken Toilet Paper Holder: 手順 3、 3の画像 3
    • After unscrewing the holder, take it off and begin unscrewing the screws in the wall. The type of screwdriver depends on the screws used.
    • Remove the clip after removing all screws. You should be left with two big holes and two small holes in the wall.
  4. How to Fix a Broken Toilet Paper Holder: 手順 4、 2の画像 1 How to Fix a Broken Toilet Paper Holder: 手順 4、 2の画像 2
    • Remove the existing anchor and drill the top hole with the 5/16" drill bit. This will make space for the new anchor to be placed.
    • Pinch the new 3/8"-1/2" anchor, place it into the top hole, and push it to be level with the wall.
  5. How to Fix a Broken Toilet Paper Holder: 手順 5、 2の画像 1 How to Fix a Broken Toilet Paper Holder: 手順 5、 2の画像 2
    • After placing the new anchor in, align the clip accordingly and proceed to screw in the anchor, starting with the top hole and then the bottom hole.
    • You have the option to use a either a screwdriver or drill (head based on the screws in possession).
  6. How to Fix a Broken Toilet Paper Holder: 手順 6、 2の画像 1 How to Fix a Broken Toilet Paper Holder: 手順 6、 2の画像 2
    • When you have completed the previous step for both sides, place the toilet paper holder in place and re-screw the Allen screw until both holders feel stiff.
ゴール
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Andrew Nammour
メンバー登録日: 07/05/20
181 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G9, Allen Summer 2020 York University, Team S1-G9, Allen Summer 2020人のメンバー
YORK-ALLEN-SU20S1G9
1 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 10
過去 7 日: 68
過去 30 日: 316
今までの合計 24,229
