メインコンテンツにスキップ
How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses
必要な工具と部品
  1. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses, How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: 手順 1、 3の画像 1 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses, How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: 手順 1、 3の画像 2 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses, How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: 手順 1、 3の画像 3
    • Apply dish soap to the broken temple arm sections.
    • Scrub the broken temple arm sections with the dish soap for one minute.
  2. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: 手順 2、 3の画像 1 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: 手順 2、 3の画像 2 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: 手順 2、 3の画像 3
    • Rinse the dish soap off of the temple arm sections with water.
    • Dry off the temple arm sections with a paper towel.
  3. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: 手順 3、 2の画像 1 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: 手順 3、 2の画像 2
  4. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: 手順 4、 3の画像 1 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: 手順 4、 3の画像 2 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: 手順 4、 3の画像 3
    • Use the coated toothpick to apply a thin layer of Gorilla Super Glue to one of the broken temple arm sections.
    • Gorilla Super Glue works better when less of the product is applied. Make sure to only apply a thin layer of glue to the broken temple arm section.
  5. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: 手順 5、 2の画像 1 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: 手順 5、 2の画像 2
    • Press the two temple arm sections together and hold for one minute.
    • Caution: Gorilla Super Glue can remain on your skin for up to a week. Place hands away from the glue applied when holding the temple sections together to keep hands clean.
  6. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: 手順 6、 3の画像 1 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: 手順 6、 3の画像 2 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: 手順 6、 3の画像 3
    • Tightly wrap masking tape around the area where you placed the temple arm sections together.
    • Leave the masking tape on for five minutes.
  7. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: 手順 7、 2の画像 1 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: 手順 7、 2の画像 2
    • Remove the masking tape.
  8. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: 手順 8、 3の画像 1 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: 手順 8、 3の画像 2 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: 手順 8、 3の画像 3
    • Select a 1/4" heat-shrinking tube.
    • Slide the tube to the area where you applied the Gorilla Super Glue.
  9. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: 手順 9、 3の画像 1 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: 手順 9、 3の画像 2 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: 手順 9、 3の画像 3
    • Plug in a handheld hair dryer.
    • Turn the handheld hair dryer to the highest heat setting.
  10. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: 手順 10、 3の画像 1 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: 手順 10、 3の画像 2 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: 手順 10、 3の画像 3
    • Circulate the handheld hair dryer around the heat-shrinking tube until it is suctioned around the temple arm.
    • Caution: Keep your fingers away from the area you are aiming the hair dryer. The hair dryer produces high levels of heat that can irritate or burn a person's skin.
ゴール
作成者
1人の作成者と共同作成されました。
Maia Michelle Brown
メンバー登録日: 02/20/24
181 ポイント
1ガイドが承認済み
チーム
University of Arizona, Team 2-9, Cools Stephens Spring 2024 University of Arizona, Team 2-9, Cools Stephens Spring 2024人のメンバー
ARIZONA-COOLS STEPHENS-S24S2G9
2 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 20
今までの合計 120
