メインコンテンツにスキップ
How to Fix a Broken Strap on a Strapback Hat
必要な工具と部品
  1. How to Fix a Broken Strap on a Strapback Hat, How to Fix a Broken Strap on a Strapback Hat: 手順 1、 3の画像 1 How to Fix a Broken Strap on a Strapback Hat, How to Fix a Broken Strap on a Strapback Hat: 手順 1、 3の画像 2 How to Fix a Broken Strap on a Strapback Hat, How to Fix a Broken Strap on a Strapback Hat: 手順 1、 3の画像 3
    • Measure the thread.
    • We recommend an arms-length amount of thread to ensure its enough to complete the fix without needing more thread.
    • Cut the thread at desired length.
  2. How to Fix a Broken Strap on a Strapback Hat: 手順 2、 2の画像 1 How to Fix a Broken Strap on a Strapback Hat: 手順 2、 2の画像 2
    • Thread the needle.
  3. How to Fix a Broken Strap on a Strapback Hat: 手順 3、 2の画像 1 How to Fix a Broken Strap on a Strapback Hat: 手順 3、 2の画像 2
    • Pull the thread through the needle until both ends of the thread meet.
    • Tie a knot at the end of the thread.
  4. How to Fix a Broken Strap on a Strapback Hat: 手順 4、 2の画像 1 How to Fix a Broken Strap on a Strapback Hat: 手順 4、 2の画像 2
    • Position the strap to where it was originally located on the hat.
  5. How to Fix a Broken Strap on a Strapback Hat: 手順 5、 2の画像 1 How to Fix a Broken Strap on a Strapback Hat: 手順 5、 2の画像 2
    • Ensure that the strap doesn't move by using a binder clip to hold it in place.
  6. How to Fix a Broken Strap on a Strapback Hat: 手順 6、 3の画像 1 How to Fix a Broken Strap on a Strapback Hat: 手順 6、 3の画像 2 How to Fix a Broken Strap on a Strapback Hat: 手順 6、 3の画像 3
    • Starting on the inside of the hat, poke the needle through the cap and loose strap.
    • Pull the needle through the fabric and out the other end.
  7. How to Fix a Broken Strap on a Strapback Hat: 手順 7、 2の画像 1 How to Fix a Broken Strap on a Strapback Hat: 手順 7、 2の画像 2
    • Move the needle a few millimeters to the left and poke the needle through the front of the hat.
    • Pull the needle out on the other end.
  8. How to Fix a Broken Strap on a Strapback Hat: 手順 8、 2の画像 1 How to Fix a Broken Strap on a Strapback Hat: 手順 8、 2の画像 2
    • Repeat steps 6 and 7 until the strap is fully sewn onto the hat.
  9. How to Fix a Broken Strap on a Strapback Hat: 手順 9、 3の画像 1 How to Fix a Broken Strap on a Strapback Hat: 手順 9、 3の画像 2 How to Fix a Broken Strap on a Strapback Hat: 手順 9、 3の画像 3
    • Tie a knot as close to the base of the hat as possible and cut the thread.
  10. How to Fix a Broken Strap on a Strapback Hat: 手順 10、 1の画像 1
    • Your hat is fixed and ready to wear!
終わりに
Congratulations! With some simple hand sewing, you were able to fix the broken strap on your hat.
作成者
5人の作成者と共同で作成されました。
Sarah Sy
メンバー登録日: 02/02/23
181 ポイント
1ガイドが承認済み
チーム
UC Davis, Team 1-1, Andersen Winter 2023 UC Davis, Team 1-1, Andersen Winter 2023人のメンバー
UCD-ANDERSEN-W23S1G1
3 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 51
過去 30 日: 235
今までの合計 1,756
