メインコンテンツにスキップ
How to Fix a Broken Seam on Pants
必要な工具と部品
  1. How to Fix a Broken Seam on Pants, Locate the repair area: 手順 1、 3の画像 1 How to Fix a Broken Seam on Pants, Locate the repair area: 手順 1、 3の画像 2 How to Fix a Broken Seam on Pants, Locate the repair area: 手順 1、 3の画像 3
    • Identify the part of the pants that needs repairing and gather all the necessary tools.
  2. How to Fix a Broken Seam on Pants, Pin the area: 手順 2、 3の画像 1 How to Fix a Broken Seam on Pants, Pin the area: 手順 2、 3の画像 2 How to Fix a Broken Seam on Pants, Pin the area: 手順 2、 3の画像 3
    • Use sewing pines or needles to pin the seam area and hold it together for the next step.
  3. How to Fix a Broken Seam on Pants, Clean the area: 手順 3、 2の画像 1 How to Fix a Broken Seam on Pants, Clean the area: 手順 3、 2の画像 2
    • Once the area has been fixed with the pins, use a seam ripper to remove the old threads.
    • If there are still any remaining loose threads, use a pair scissors to cut them.
  4. How to Fix a Broken Seam on Pants, Start stitching: 手順 4、 3の画像 1 How to Fix a Broken Seam on Pants, Start stitching: 手順 4、 3の画像 2 How to Fix a Broken Seam on Pants, Start stitching: 手順 4、 3の画像 3
    • Use a sewing machine to stitch the marked area.
    • Finish up the stitch by cutting any loose threads with a pair of scissors.
  5. How to Fix a Broken Seam on Pants, Finished and ready!: 手順 5、 3の画像 1 How to Fix a Broken Seam on Pants, Finished and ready!: 手順 5、 3の画像 2 How to Fix a Broken Seam on Pants, Finished and ready!: 手順 5、 3の画像 3
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
終わりに
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
作成者
1人の作成者と共同作成されました。
Ben Blischke
メンバー登録日: 07/19/23
10,230 ポイント
66のガイドは作成済み
チーム
INTERSPORT INTERSPORT人のメンバー
Community
25 メンバー
169のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 48
今までの合計 602
