メインコンテンツにスキップ
How to Fix a Bent Intel CPU Socket Pin
必要な工具と部品
  1. How to Fix a Bent Intel CPU Socket Pin, How to Fix a Bent Intel CPU Socket Pin: 手順 1、 1の画像 1
    • Make sure you safely removed your motherboard from your computer.
    • Place your motherboard on a table, or on any grounded surface that you are comfortable to work on.
  2. How to Fix a Bent Intel CPU Socket Pin: 手順 2、 2の画像 1 How to Fix a Bent Intel CPU Socket Pin: 手順 2、 2の画像 2
    • Unplug the CPU power cable connected to the motherboard.
    • Don't pull the CPU Power cable by the wires to avoid damaging them and the CPU power pins.
  3. How to Fix a Bent Intel CPU Socket Pin: 手順 3、 1の画像 1
    • Now, if you have an Intel Cooling Fan, turn the four pins on the CPU cooler counterclockwise.
    • Then pull all four pins to remove the CPU cooler off the motherboard.
    • If you have a different cooler, or an aftermarket cooler, read your manual for your other cooler to see how to properly remove the cooler.
  4. How to Fix a Bent Intel CPU Socket Pin: 手順 4、 2の画像 1 How to Fix a Bent Intel CPU Socket Pin: 手順 4、 2の画像 2
    • Now remove the CPU cooler off your motherboard, and place the cooler aside.
  5. How to Fix a Bent Intel CPU Socket Pin: 手順 5、 3の画像 1 How to Fix a Bent Intel CPU Socket Pin: 手順 5、 3の画像 2 How to Fix a Bent Intel CPU Socket Pin: 手順 5、 3の画像 3
    • Lift the metal clamp in order to remove the CPU itself. To do this particular step, there is a metal tab which you can push with a little force to carefully raise the metal clamp away after loosening the metal tab.
    • Do not be afraid to use a bit of force when moving the metal tab.
  6. How to Fix a Bent Intel CPU Socket Pin: 手順 6、 2の画像 1 How to Fix a Bent Intel CPU Socket Pin: 手順 6、 2の画像 2
    • With your thumb and middle finger, remove the CPU off the motherboard.
    • (Optional) You can clean your CPU with rubbing alcohol. In this guide, you don't have to.
  7. How to Fix a Bent Intel CPU Socket Pin: 手順 7、 2の画像 1 How to Fix a Bent Intel CPU Socket Pin: 手順 7、 2の画像 2
    • As you can see, there are a few bent pins in the CPU socket. It it a bit hard to see the pins since they are very tiny. So, you'll need a needle or any tool to fix the pins in the right directions.
    • Use a needle and gently bend the CPU pins in the right direction where the other CPU pins are facing.
    • Carefully move the pins direction where they are meant to face, because the pins are very fragile.
  8. How to Fix a Bent Intel CPU Socket Pin: 手順 8、 2の画像 1 How to Fix a Bent Intel CPU Socket Pin: 手順 8、 2の画像 2
    • After fixing the pins, gently place your CPU with your thumb and middle finger into the socket.
    • When reinstalling your CPU back onto the motherboard, try not touch the bottom of the CPU.
  9. How to Fix a Bent Intel CPU Socket Pin: 手順 9、 3の画像 1 How to Fix a Bent Intel CPU Socket Pin: 手順 9、 3の画像 2 How to Fix a Bent Intel CPU Socket Pin: 手順 9、 3の画像 3
    • Lock the CPU tray so that the CPU does not fall out of place. You will need a bit of force to push the lock.
  10. How to Fix a Bent Intel CPU Socket Pin: 手順 10、 3の画像 1 How to Fix a Bent Intel CPU Socket Pin: 手順 10、 3の画像 2 How to Fix a Bent Intel CPU Socket Pin: 手順 10、 3の画像 3
    • Reinstall the CPU cooler and replace the four pins turning them clockwise to secure it to the motherboard.
  11. How to Fix a Bent Intel CPU Socket Pin: 手順 11、 2の画像 1 How to Fix a Bent Intel CPU Socket Pin: 手順 11、 2の画像 2
    • Plug CPU power cable back into the motherboard.
  12. How to Fix a Bent Intel CPU Socket Pin: 手順 12、 2の画像 1 How to Fix a Bent Intel CPU Socket Pin: 手順 12、 2の画像 2
    • And now you have completed this fix!
    • Now all you need to do is to place the motherboard back into your computer, and test to see if you can boot into the BIOS screen.
    • The guide only shows how to fix the CPU pin sockets. Putting the motherboard back into your computer will take more time.
終わりに
Overall, this is the only way to fix of having the CPU undetectable from the motherboard, and enabling dual-channel memory. Some people have to RMA (Return Merchandise Authorization) or return their motherboard to their manufacturer, and receiving with a replacement. RMA’s may take time to receive their replacements, depending of the manufacturer.
6 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Nam
メンバー登録日: 01/12/21
367 ポイント
1ガイドが承認済み
チーム
York University, Team S2-G13, O'Regan Winter 2021 York University, Team S2-G13, O'Regan Winter 2021人のメンバー
YORK-O'REGAN-W21S2G13
1 メンバー
2のガイドは作成済み
1件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 55
過去 30 日: 297
今までの合計 31,581
