メインコンテンツにスキップ
How to Fix Your Cosplay Rabbit Ears
必要な工具と部品
  1. How to Fix Your Cosplay Rabbit Ears, How to Fix Your Cosplay Rabbit Ears: 手順 1、 2の画像 1 How to Fix Your Cosplay Rabbit Ears, How to Fix Your Cosplay Rabbit Ears: 手順 1、 2の画像 2
    • Rip the ears off of the headband.
    • They are attached with glue, as seen in the photo.
    • Set the headband aside for now.
  2. How to Fix Your Cosplay Rabbit Ears: 手順 2、 3の画像 1 How to Fix Your Cosplay Rabbit Ears: 手順 2、 3の画像 2 How to Fix Your Cosplay Rabbit Ears: 手順 2、 3の画像 3
    • Cut a small hole into the middle backside of the ear, vertically, to remove the wired structure.
    • The hole should be 1-2 inches long.
    • Feel around on the inside of the ear until you find the black wire.
    • Pull out the wire.
    • It is not attached to anything, so it will come out easily.
  3. How to Fix Your Cosplay Rabbit Ears: 手順 3、 3の画像 1 How to Fix Your Cosplay Rabbit Ears: 手順 3、 3の画像 2 How to Fix Your Cosplay Rabbit Ears: 手順 3、 3の画像 3
    • Straighten the wire completely.
    • Double the wire by bending it in half.
    • Bend one end a couple of times over, as seen in the pictures. This end will be the bottom base of the ear.
    • Add the wire back into the fabric ear, with the thicker end at the bottom of the ear. Make sure it is centered.
  4. How to Fix Your Cosplay Rabbit Ears: 手順 4、 2の画像 1 How to Fix Your Cosplay Rabbit Ears: 手順 4、 2の画像 2
    • Thread your needle and do a simple stitch along the cut to sew up the hole from the wire.
  5. How to Fix Your Cosplay Rabbit Ears: 手順 5、 3の画像 1 How to Fix Your Cosplay Rabbit Ears: 手順 5、 3の画像 2 How to Fix Your Cosplay Rabbit Ears: 手順 5、 3の画像 3
    • When sewing down the wire, make sure that the wire is completely centered.
    • Sew a simple stitch along and down the wire, looping the needle over and under it.
  6. How to Fix Your Cosplay Rabbit Ears: 手順 6、 2の画像 1 How to Fix Your Cosplay Rabbit Ears: 手順 6、 2の画像 2
    • Measure out a small piece of white fabric.
    • The measurements should be around 1 inch by 4 inches.
    • Cut out two strips of this measurement.
  7. How to Fix Your Cosplay Rabbit Ears: 手順 7、 3の画像 1 How to Fix Your Cosplay Rabbit Ears: 手順 7、 3の画像 2 How to Fix Your Cosplay Rabbit Ears: 手順 7、 3の画像 3
    • Wrap the fabric around one side of the headband, relatively tight.
    • Sew along the headband, as seen in the pictures. You should be able to slide the fabric off of the headband afterward.
  8. How to Fix Your Cosplay Rabbit Ears: 手順 8、 2の画像 1 How to Fix Your Cosplay Rabbit Ears: 手順 8、 2の画像 2
    • Spread the two sides of the fabric strip out and place it on the base of the ear.
    • Sew each side down securely.
    • Slip the headband back into the fabric on both ears to make sure it is stable.
  9. How to Fix Your Cosplay Rabbit Ears: 手順 9、 3の画像 1 How to Fix Your Cosplay Rabbit Ears: 手順 9、 3の画像 2 How to Fix Your Cosplay Rabbit Ears: 手順 9、 3の画像 3
    • Your ears and now finished! They should stick up perfectly and be able to bend in different directions.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Ella Tschetter
メンバー登録日: 01/20/21
196 ポイント
1ガイドが承認済み
チーム
コメント 1 件
why does this exist
Ryan Sturt - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 24
過去 30 日: 64
今までの合計 847
