メインコンテンツにスキップ
How to Fix Warped LEGO Baseplates
必要な工具と部品
  1. How to Fix Warped LEGO Baseplates, How to Fix Warped LEGO Baseplates: 手順 1、 1の画像 1
    • Grab a pot large enough to place the LEGO baseplate in.
    • Fill the pot full of tap water, enough to submerge the baseplate completely.
  2. How to Fix Warped LEGO Baseplates: 手順 2、 3の画像 1 How to Fix Warped LEGO Baseplates: 手順 2、 3の画像 2 How to Fix Warped LEGO Baseplates: 手順 2、 3の画像 3
    • Place the pot of water on a stove.
    • Turn the stove burner on to medium heat.
    • Heat the water to approximately 100 degrees Fahrenheit. Use a thermometer to ensure proper heat.
    • Do not heat water near or above a temperature of 140 degrees Fahrenheit to avoid damaging/melting the plastic.
  3. How to Fix Warped LEGO Baseplates: 手順 3、 3の画像 1 How to Fix Warped LEGO Baseplates: 手順 3、 3の画像 2 How to Fix Warped LEGO Baseplates: 手順 3、 3の画像 3
    • Place the LEGO baseplate in the pot of heated water for 5-7 minutes.
    • Ensure that the LEGO baseplate is fully submerged for the entire heating duration.
  4. How to Fix Warped LEGO Baseplates: 手順 4、 1の画像 1
    • Turn the stove off and remove the baseplate from the water.
    • Dry the LEGO baseplate using a paper towel.
  5. How to Fix Warped LEGO Baseplates: 手順 5、 1の画像 1
    • Quickly sandwich the baseplate between two flat baking pans while the baseplate is still warm.
    • You can use any two flat, sturdy objects if baking pans are unavailable.
  6. How to Fix Warped LEGO Baseplates: 手順 6、 2の画像 1 How to Fix Warped LEGO Baseplates: 手順 6、 2の画像 2
    • Place two plastic clamps over the two pans to evenly apply firm pressure against the baseplate.
    • If clamps are unavailable, you can use weights to apply similar pressure.
    • Leave the LEGO baseplate in between the pressure of the baking pans for at least 5 hours.
終わりに
If your LEGO baseplate is still warped after the 5 hours of sitting in between the clamps, repeat process and leave the LEGO baseplate in between clamps for an additional 5 hours.
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Nicole DeFer
メンバー登録日: 09/26/22
224 ポイント
1ガイドが承認済み
チーム
CSU Fullerton, Team 1-5, Bruce Fall 2022 CSU Fullerton, Team 1-5, Bruce Fall 2022人のメンバー
CSUF-BRUCE-F22S1G5
2 メンバー
3のガイドは作成済み
1件のガイドコメント
100 degrees doesn't seem hot enough.
michael kithcart - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 60
今までの合計 3,718
