メインコンテンツにスキップ
How to Fix Sticky Surfaces on a Cast Iron Skillet
必要な工具と部品
  1. How to Fix Sticky Surfaces on a Cast Iron Skillet, How to Fix Sticky Surfaces on a Cast Iron Skillet: 手順 1、 1の画像 1
    • Clean the skillet thoroughly with soap and water.
  2. How to Fix Sticky Surfaces on a Cast Iron Skillet: 手順 2、 2の画像 1 How to Fix Sticky Surfaces on a Cast Iron Skillet: 手順 2、 2の画像 2
    • Scrub the entire pan with steel wool.
    • After scrubbing the skillet, dry it off using a towel or paper towels. You can also place the skillet on a stove top for 30-45 seconds to dry it.
    • The layer of seasoning has now been completely removed, and will be restored in the following steps.
  3. How to Fix Sticky Surfaces on a Cast Iron Skillet: 手順 3、 1の画像 1
    • Pre-heat the oven to 500°F. (If your oven does not go this high, use the highest temperature.)
  4. How to Fix Sticky Surfaces on a Cast Iron Skillet: 手順 4、 3の画像 1 How to Fix Sticky Surfaces on a Cast Iron Skillet: 手順 4、 3の画像 2 How to Fix Sticky Surfaces on a Cast Iron Skillet: 手順 4、 3の画像 3
    • Lightly coat the skillet in a thin layer of vegetable oil.
    • Use a paper towel to evenly spread the oil over the entire pan, including the handle bar. The skillet should look somewhat shiny after this.
    • Grab a dry paper towel and go over the surfaces one more time to remove excess oil.
  5. How to Fix Sticky Surfaces on a Cast Iron Skillet: 手順 5、 1の画像 1
    • Place skillet in the oven upside down for 1 hour.
    • Place a piece of aluminum foil under the pan in case any oil drips.
  6. How to Fix Sticky Surfaces on a Cast Iron Skillet: 手順 6、 1の画像 1
    • After one hour, remove the skillet from the oven using an oven mitt.
終わりに
The skillet should no longer have any sticky surfaces, and should cook as if it were new. To prevent damage to the seasoned layer, be careful with metal spatulas and make sure to only wash the skillet with soap and steel wool if you are removing a damaged layer to apply a new one.
作成者
1人の作成者と共同作成されました。
Liam McKenzie
メンバー登録日: 03/22/21
133 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team S1-G13, Sinclaire Spring 2021 UMass Dartmouth, Team S1-G13, Sinclaire Spring 2021人のメンバー
UMASSD-SINCLAIRE-S21S1G13
1 メンバー
2のガイドは作成済み
3 件のコメント
Step number 6 kinda leaves me hanging. Is there anything else to do, or a Step 7?
David Rhodes - 返信
That’s it. The only thing left to do now is cook an awesome dish in your cast iron.
Stacy White -
What temperature do you season your cast iron in the oven?
Connie - 返信
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 51
過去 30 日: 263
今までの合計 6,388
