メインコンテンツにスキップ
How to Fix Sticky Keys on Ducky One 2 SF Mechanical Keyboard
必要な工具と部品
  1. How to Fix Sticky Keys on Ducky One 2 SF Mechanical Keyboard, How to Fix Sticky Keys on Ducky One 2 SF Mechanical Keyboard: 手順 1、 1の画像 1
    • Before starting the disassembly of your device, be sure to disconnect your keyboard from your computer.
    • Grab the USB-C cable with two fingers and pull it out of the port on the back of the keyboard.
    • When the keyboard's lights go out, that indicates it has been turned off properly.
  2. How to Fix Sticky Keys on Ducky One 2 SF Mechanical Keyboard: 手順 2、 1の画像 1
    • Dip a Q-tip or cotton ball in rubbing alcohol. Any rubbing alcohol is fine.
    • Make sure the Q-tip or cotton ball isn't dripping but is very damp with the alcohol.
    • The step will require multiple Q-tips or cotton balls.
  3. How to Fix Sticky Keys on Ducky One 2 SF Mechanical Keyboard: 手順 3、 1の画像 1
    • Using the Q-tips, rub the outside of all the keys that may be affected.
    • If the keys are really dirty, you may need to apply some force in order to scrub the grime off the keys.
  4. How to Fix Sticky Keys on Ducky One 2 SF Mechanical Keyboard: 手順 4、 1の画像 1
    • Once you have cleaned the top of the keys with rubbing alcohol, remove the key caps from the switches using the key prying tool.
    • You may have to apply force to disconnect the caps. This is normal; no need to worry about breaking them.
  5. How to Fix Sticky Keys on Ducky One 2 SF Mechanical Keyboard: 手順 5、 1の画像 1
    • After removing the key caps from the board, the switches will be available to clean.
  6. How to Fix Sticky Keys on Ducky One 2 SF Mechanical Keyboard: 手順 6、 1の画像 1
    • Put any dirty key caps in a small glass with a soap and water solution and let them soak for 3 to 5 minutes.
    • Since the caps are plastic, soaking them for only a few minutes is safe.
    • Remember to let the keycaps dry after removing them from the glass. This is to make sure there no future water damage.
  7. How to Fix Sticky Keys on Ducky One 2 SF Mechanical Keyboard: 手順 7、 1の画像 1
    • Use an electronics duster or a can of compressed air to remove any hair, dust, or crumbs that may have fallen under the key caps.
    • To be more thorough with your cleaning, make sure to apply air to the keycaps still on the keyboard to remove anything that can be hiding under those as well.
  8. How to Fix Sticky Keys on Ducky One 2 SF Mechanical Keyboard: 手順 8、 1の画像 1
    • Using the Q-tip or cotton ball with rubbing alcohol, clean the top and around the base of the switches.
  9. How to Fix Sticky Keys on Ducky One 2 SF Mechanical Keyboard: 手順 9、 1の画像 1
    • To replace the key caps, line them up with the cutouts on each switch and push down.
    • Make sure to let the keyboard dry before putting the keycaps back on your switches. This is a precautionary step to prevent future damage.
    • Once you have reassembled the keys, press the ones you have repaired 5 to 10 times making sure you have cleaned and fixed them properly.
    • Remember these key caps are plastic, so you can apply a little more pressure than normal when putting them back on.
終わりに
To re-assemble your keyboard, put the keycaps on the correct spot of the keyboard and push down to secure the caps.
作成者
2人の作成者と共同で作成されました。
William Rhotenberry
メンバー登録日: 10/14/20
169 ポイント
1ガイドが承認済み
チーム
Texas Tech, Team S14-G10, Cowan Fall 2020 Texas Tech, Team S14-G10, Cowan Fall 2020人のメンバー
TTU-COWAN-F20S14G10
1 メンバー
2のガイドは作成済み
コメント 1 件
Hola,
tengo un ducky one 2 mini y dejo de repente de funcionar una fila de teclas desde la X a la M.
actualice el firmware al 1.10 pero sigue igual.
me puedes ayudar?
gracias.
JESS - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 25
過去 30 日: 117
今までの合計 5,211
