メインコンテンツにスキップ
How to Fix Sagging IKEA Lack Shelves
必要な工具と部品
  1. How to Fix Sagging IKEA Lack Shelves, How to Fix Sagging IKEA Lack Shelves: 手順 1、 3の画像 1 How to Fix Sagging IKEA Lack Shelves, How to Fix Sagging IKEA Lack Shelves: 手順 1、 3の画像 2 How to Fix Sagging IKEA Lack Shelves, How to Fix Sagging IKEA Lack Shelves: 手順 1、 3の画像 3
    • Hold the shelf on both sides and push it upwards. Slowly pull the shelf out to expose the anchored screws.
  2. How to Fix Sagging IKEA Lack Shelves: 手順 2、 3の画像 1 How to Fix Sagging IKEA Lack Shelves: 手順 2、 3の画像 2 How to Fix Sagging IKEA Lack Shelves: 手順 2、 3の画像 3
    • Pull out the loose screws and plugs to expose the holes in the wall.
    • Drill into these holes using a cordless power drill machine to even out the edge of the holes and to make sure the hole is deep enough for the new screws and plugs.
  3. How to Fix Sagging IKEA Lack Shelves: 手順 3、 3の画像 1 How to Fix Sagging IKEA Lack Shelves: 手順 3、 3の画像 2 How to Fix Sagging IKEA Lack Shelves: 手順 3、 3の画像 3
    • Apply the drywall filler into the holes and also over the holes to cover it.
    • This filler becomes hard as concrete when it dries, It will hold the screw firmly in place.
  4. How to Fix Sagging IKEA Lack Shelves: 手順 4、 3の画像 1 How to Fix Sagging IKEA Lack Shelves: 手順 4、 3の画像 2 How to Fix Sagging IKEA Lack Shelves: 手順 4、 3の画像 3
    • Smooth out the drywall filler using a taping knife.
    • Applying poly filler over the holes and smoothing it out will create an even texture and hide the edges of each hole.
  5. How to Fix Sagging IKEA Lack Shelves: 手順 5、 3の画像 1 How to Fix Sagging IKEA Lack Shelves: 手順 5、 3の画像 2 How to Fix Sagging IKEA Lack Shelves: 手順 5、 3の画像 3
    • Insert a Phillips #10 screw and plug into each hole carefully.
    • Make sure the wall plug is pushed inside entirely, only exposing the edges.
  6. How to Fix Sagging IKEA Lack Shelves: 手順 6、 3の画像 1 How to Fix Sagging IKEA Lack Shelves: 手順 6、 3の画像 2 How to Fix Sagging IKEA Lack Shelves: 手順 6、 3の画像 3
    • When the wall plug and screw is pushed into the hole, the smoothed out drywall filler will become messy around the edges.
    • Using the taping knife, carefully smooth out the drywall filler around the screws.
  7. How to Fix Sagging IKEA Lack Shelves: 手順 7、 3の画像 1 How to Fix Sagging IKEA Lack Shelves: 手順 7、 3の画像 2 How to Fix Sagging IKEA Lack Shelves: 手順 7、 3の画像 3
    • Now proceed to drive the screw into the wall plug and secure it in place.
    • Drive the screw-in until 1-1.5inch space is left between the wall and the screw head.
  8. How to Fix Sagging IKEA Lack Shelves: 手順 8、 3の画像 1 How to Fix Sagging IKEA Lack Shelves: 手順 8、 3の画像 2 How to Fix Sagging IKEA Lack Shelves: 手順 8、 3の画像 3
    • Apply more drywall filler over the edges of the wall plug to hide it.
    • Using the taping knife, smooth out the drywall filler.
    • This step may look redundant but it is necessary to secure the screw and plug firmly.
  9. How to Fix Sagging IKEA Lack Shelves: 手順 9、 3の画像 1 How to Fix Sagging IKEA Lack Shelves: 手順 9、 3の画像 2 How to Fix Sagging IKEA Lack Shelves: 手順 9、 3の画像 3
    • After the drywall filler hardens. it is time to insert the shelf in place.
    • Insert the round side of the hook into each screw. Then push the shelf downwards until it is level to secure it in place.
終わりに
The shelf is now fixed!
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Sanjana Salam
メンバー登録日: 01/15/21
223 ポイント
1ガイドが承認済み
チーム
York University, Team S2-G23, O'Regan Winter 2021 York University, Team S2-G23, O'Regan Winter 2021人のメンバー
YORK-O'REGAN-W21S2G23
1 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 35
過去 7 日: 214
過去 30 日: 1,093
今までの合計 112,477
