メインコンテンツにスキップ
How to Fix PS4 Controller Analog Drift (R3 or L3 not working)
必要な工具と部品
  1. How to Fix PS4 Controller Analog Drift (R3 or L3 not working), How to Fix PS4 Controller Analog Drift (R3 or L3 not working): 手順 1、 2の画像 1 How to Fix PS4 Controller Analog Drift (R3 or L3 not working), How to Fix PS4 Controller Analog Drift (R3 or L3 not working): 手順 1、 2の画像 2
    • Remove the four screws from the back of your controller using a Phillips #0 screwdriver.
    • Separate the front and the back of the controller.
  2. How to Fix PS4 Controller Analog Drift (R3 or L3 not working): 手順 2、 3の画像 1 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): 手順 2、 3の画像 2 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): 手順 2、 3の画像 3
    • Unplug the ribbon cable to disconnect the Micro-USB Type B port from the controller itself.
    • Be careful not to tear or damage the cable.
  3. How to Fix PS4 Controller Analog Drift (R3 or L3 not working): 手順 3、 1の画像 1
    • Unplug the battery from the controller and take it out.
    • Be careful not to tear or damage the wire as this is an important component for your controller.
  4. How to Fix PS4 Controller Analog Drift (R3 or L3 not working): 手順 4、 3の画像 1 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): 手順 4、 3の画像 2 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): 手順 4、 3の画像 3
    • Remove the single screw from the black plate covering the motherboard using a Phillips #0 screwdriver.
    • Remove the black plate from the controller.
  5. How to Fix PS4 Controller Analog Drift (R3 or L3 not working): 手順 5、 3の画像 1 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): 手順 5、 3の画像 2 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): 手順 5、 3の画像 3
    • Disconnect the ribbon cable that connects the back of the controller to the motherboard.
    • Remove the motherboard from the back of the controller.
    • Be careful not to tear or damage this wire as it is important for your controller.
  6. How to Fix PS4 Controller Analog Drift (R3 or L3 not working): 手順 6、 3の画像 1 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): 手順 6、 3の画像 2 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): 手順 6、 3の画像 3
    • Remove the toggle sticks from the controller.
    • Be careful of the sensors as they are very sensitive.
  7. How to Fix PS4 Controller Analog Drift (R3 or L3 not working): 手順 7、 3の画像 1 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): 手順 7、 3の画像 2 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): 手順 7、 3の画像 3
    • Use a spudger to pry open the toggle stick sensor.
    • Use a cotton swab with a little bit of rubbing alcohol to remove the grease and build-up from the sensor.
  8. How to Fix PS4 Controller Analog Drift (R3 or L3 not working): 手順 8、 2の画像 1 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): 手順 8、 2の画像 2
    • To reassemble the controller, place the back cover onto the motherboard.
    • Slip the red wire through the controller cover and plug it in.
  9. How to Fix PS4 Controller Analog Drift (R3 or L3 not working): 手順 9、 2の画像 1 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): 手順 9、 2の画像 2
    • Put the black plate back on top of the motherboard and screw it in.
    • Make sure the back of the controller and the motherboard are firmly connected.
  10. How to Fix PS4 Controller Analog Drift (R3 or L3 not working): 手順 10、 3の画像 1 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): 手順 10、 3の画像 2 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): 手順 10、 3の画像 3
    • Plug the battery back in and put it in its place.
    • Plug the white wire back into the motherboard.
  11. How to Fix PS4 Controller Analog Drift (R3 or L3 not working): 手順 11、 2の画像 1 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): 手順 11、 2の画像 2
    • Connect the front cover and the back cover of the controller and screw the four screws back in.
  12. How to Fix PS4 Controller Analog Drift (R3 or L3 not working): 手順 12、 1の画像 1
    • You're all done.
ゴール
47 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Sabih Akram
メンバー登録日: 09/20/20
1,666 ポイント
2のガイドは作成済み
チーム
York University, Team S13-G3, Allen Summer 2021 York University, Team S13-G3, Allen Summer 2021人のメンバー
YORK-ALLEN-SU21S13G3
1 メンバー
7のガイドは作成済み
5 件のコメント
Thank you for this!! So many great pictures!! :D
The drift for me also prevented or interrupted movement with the left analog stick. Menus would continue to scroll after i scrolled them or wouldn’t move my character on screen.
briandewitt - 返信
Nach Wechsel der Potis hatte mein Controller Drift an beiden Achsen. Das liegt daran, dass die Potis nicht 100% mit denen der Werkskalibrierten übereinstimmen. Eine nachträgliche Kalibrierung ist leider nicht so einfach möglich, da die Korrekturdaten im EEPROM des Controllers gespeichert sind. Deshalb habe ich parallel zu den Potis je einen 2MOhm Poti gelötet, mit denen der Spannungsoffset kompensiert werden kann. Ergebnis: Keine Drift mehr. Die Controller arbeiten wieder einwandfrei.
zapf2000 - 返信
Well organised pictorial lecture.great work.
Egeonu - 返信
Great walkthrough and high-res images makes the job a lot smoother. Only remark I have are three things: 1) There are four clips that are hard to see on the images, and aren’t detailed; they are on the top right and left, under the “SHARE” and “OPTIONS” buttons, as well as the two clips on either side of the docking port. These easily break, although I avoided that. 2) The sensor housing have very fragile clips which easily break after a repair or two. DO NOT USE FORCE ON THESE! If you’re in doubt, just try and blow some air into them. Some remaining dirt is better than a broken stick. I also avoided this thanks to a comment on the step, but I’ve heard many has broken their sensors doing this. 3) The USB connector isn’t labeled as a pull-out connector. This isn’t much of an issue, but in sub-par lit environments, it looks like a clip connector. Have some friends ruining their USB ports due to ripping the connector off the PCB, thinking it’s a clip connector.
Franz Rolfsvaag - 返信
tidak membantu sama sekali seperti padi yang terbanjiri dan tidak bisa di proses untuk menjadi nasi lalu di nikmati
Dzakwan Afiq - 返信
コメントを追加
統計データ:
過去 24時間: 51
過去 7 日: 420
過去 30 日: 2,017
今までの合計 62,746
