メインコンテンツにスキップ
How to Fix Loose Temples on Plastic Framed Reading Glasses
必要な工具と部品
  1. How to Fix Loose Temples on Plastic Framed Reading Glasses, How to Fix Loose Temples on Plastic Framed Reading Glasses: 手順 1、 3の画像 1 How to Fix Loose Temples on Plastic Framed Reading Glasses, How to Fix Loose Temples on Plastic Framed Reading Glasses: 手順 1、 3の画像 2 How to Fix Loose Temples on Plastic Framed Reading Glasses, How to Fix Loose Temples on Plastic Framed Reading Glasses: 手順 1、 3の画像 3
    • Fold the temples of the glasses inwards to feel which arm has less resistence.
  2. How to Fix Loose Temples on Plastic Framed Reading Glasses: 手順 2、 1の画像 1
    • Locate the hinge screw on the arm that had less give.
    • The steps to replace the screw will be the exact same for both hinges.
  3. How to Fix Loose Temples on Plastic Framed Reading Glasses: 手順 3、 1の画像 1
    • Test each screwdriver until the correct fit is found.
    • You may have to test every screwdriver to find the correct fit.
    • The screwdriver that we used was the #2 mm screwdriver.
  4. How to Fix Loose Temples on Plastic Framed Reading Glasses: 手順 4、 3の画像 1 How to Fix Loose Temples on Plastic Framed Reading Glasses: 手順 4、 3の画像 2 How to Fix Loose Temples on Plastic Framed Reading Glasses: 手順 4、 3の画像 3
    • Insert the correct screwdriver into the screw and gently apply pressure.
    • Turn the screwdriver counterclockwise to unscrew the screw.
  5. How to Fix Loose Temples on Plastic Framed Reading Glasses: 手順 5、 1の画像 1
    • Match the screw from the screwdriver kit.
    • Individually insert each screw into the eyeglasses. Different glasses use different screws.
  6. How to Fix Loose Temples on Plastic Framed Reading Glasses: 手順 6、 1の画像 1
    • Insert the correct screwdriver into the screw.
  7. How to Fix Loose Temples on Plastic Framed Reading Glasses: 手順 7、 3の画像 1 How to Fix Loose Temples on Plastic Framed Reading Glasses: 手順 7、 3の画像 2 How to Fix Loose Temples on Plastic Framed Reading Glasses: 手順 7、 3の画像 3
    • Turn the screwdriver clockwise to tighten.
    • Tighten the screw until you feel a slight resistance.
    • Do not over-tighten the screw.
ゴール
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
John
メンバー登録日: 09/28/21
181 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team 1-5, Raign Fall 2021 University of North Texas, Team 1-5, Raign Fall 2021人のメンバー
UNT-RAIGN-F21S1G5
2 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 61
過去 30 日: 285
今までの合計 7,336
