はじめに
Water leaks for the Keurig B70 Brewing System are sometimes caused by an internal disconnection of the water pump and reservoir. Use this guide to open the Keurig and reseat the water pump.
必要な工具と部品
Move the brewer so that the metal baseplate is easily accessible.
Remove the five silver 4 mm Phillips #2 screws from the baseplate.
Remove the two silver 4mm Phillips #2 screws that hold the water pump in place.
ある他の人がこのガイドを完成しました。
