メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
If your Switch Pro Controller’s D-Pad is being overly sensitive and causing accidental directional presses, this is the guide for you to follow!
  1. The left and right grip screws are held in place with one J00 screw each. After the screw is removed, the grip slides straight off. The left and right grip screws are held in place with one J00 screw each. After the screw is removed, the grip slides straight off. The left and right grip screws are held in place with one J00 screw each. After the screw is removed, the grip slides straight off.
    • The left and right grip screws are held in place with one J00 screw each. After the screw is removed, the grip slides straight off.
  2. Remove four more J00 screws holding the back plate in place. Once they are removed, the back plate will just pop off with little to no force.
    • Remove four more J00 screws holding the back plate in place.
    • Once they are removed, the back plate will just pop off with little to no force.
  3. The battery is super easy to remove! Thanks, Nintendo! Also, it's the same battery as what powers a 3DS (they're even interchangeable!)! Neat! Remove an additional J00 screw. Remove an additional four J00 screws. The two in the battery bay are very easy to miss!
    • The battery is super easy to remove! Thanks, Nintendo! Also, it's the same battery as what powers a 3DS (they're even interchangeable!)! Neat!
    • Remove an additional J00 screw.
    • Remove an additional four J00 screws. The two in the battery bay are very easy to miss!
    • A closeup of the edge screws (also very easy to miss!).
  4. The Essential Toolkit
    コンパクト版iFixitキットの中で最も利便性の高いツール
    ショップを見る
    ショップを見る
  5. Use a pry tool or your fingernail to gently pull the two halves of the controller apart. Beware of the ribbon cable connecting the two boards!
    • Use a pry tool or your fingernail to gently pull the two halves of the controller apart. Beware of the ribbon cable connecting the two boards!
    • This is a ZIF connector. The black tab on the connector pops straight up, allowing you to gently pull the cable straight out of the lock. I removed the cable from the board with the control sticks.
  6. Disconnect the ribbon cable that connects the plate to the controller board.
    • Disconnect the ribbon cable that connects the plate to the controller board.
    • Afterward, remove two black J00 screws holding the plate onto the PCB.
  7. Remove two more black J00 screws holding the board in place.
    • Remove two more black J00 screws holding the board in place.
    • Reassembly tip: be very careful with the right screw, as it can crimp the ribbon cable if you're not careful!
  8. Voila! Here are the D-Pad touch sensors. I have outlined the area you want to cover in red. Using tape (I recommend black electrical tape, but others have said it works with clear scotch or packing tape, just be aware it may pull up after a while and cause buttons to stick!), cover the highlighted areas. This really cuts down on accidental button presses.
    • Voila! Here are the D-Pad touch sensors. I have outlined the area you want to cover in red.
    • Using tape (I recommend black electrical tape, but others have said it works with clear scotch or packing tape, just be aware it may pull up after a while and cause buttons to stick!), cover the highlighted areas. This really cuts down on accidental button presses.
    • After some testing, I applied the tape to the top and bottom touch connectors. This resulted in the smoothest operation with fewest accidental button presses. Always be sure to test (and make sure you like how it feels!) before you complete reassembly.
    • To reassemble your (expensive) controller, simply follow these steps in reverse. Happy fixing, guys!
終わりに
Hopefully, this guide was simple and easy to follow - just as the actual fix is. My controller is night and day in regards to sensitivity! Have a great day, guys - and happy fixing!
9 の人々がこのガイドを完成させました。
Robbie Kincaid
メンバー登録日: 2019年04月23日
406 ポイント
1ガイドが承認済み
11 件のコメント
Thanks!! I got a bit confused on the 2nd ribbon cable because I wasn’t sure if it was a latch like the first but it worked out. Also reassembling the ribbon cables was a bit difficult and I wasn’t exactly sure how much I had to “plug” them in before closing the latch but I figured it out, thank you! Controller works wonderfully now.
Logan Henry - 返信
Glad to hear it! Thank you for your comment!
Robbie Kincaid -
Any issues using kapton tape instead of electrical tape?
Mirleis - 返信
Not to my knowledge (I don’t have any on hand to test with though). May be worth a shot!
Robbie Kincaid -
It should be noted that the official iFixit kit is recommended for the back screw removal (especially the ones at 11 and 1 o clock by the battery compartment) or you should have a screwdriver that is skinny enough to get it straight on. I barely got it with the iFixit kit and maybe left them a little bit loose because of that. Otherwise, this guide is very good for disassembling and cleaning.
Peter Fischbach - 返信
コメントを追加
統計データを表示:
過去 24時間: 5
過去 7 日: 25
過去 30 日: 165
今までの合計 4,407
