メインコンテンツにスキップ
How to Fix Chipped Wood Furniture
必要な工具と部品
  1. How to Fix Chipped Wood Furniture, How to Fix Chipped Wood Furniture: 手順 1、 2の画像 1 How to Fix Chipped Wood Furniture, How to Fix Chipped Wood Furniture: 手順 1、 2の画像 2
    • Clean the affected/damaged area of the wood and remove any dust or small wood particles using a clean brush or a paper towel.
  2. How to Fix Chipped Wood Furniture: 手順 2、 2の画像 1 How to Fix Chipped Wood Furniture: 手順 2、 2の画像 2
    • If the damage is affecting a larger area, use an electric or cordless drill with a small to medium sized drill bit and create small and shallow craters onto the chipped wood
    • This process is done so that the wood filler, used later on, has more surface area to adhere firmly
    • The drill should only be used to create small, shallow craters not holes in the furniture.
  3. How to Fix Chipped Wood Furniture: 手順 3、 2の画像 1 How to Fix Chipped Wood Furniture: 手順 3、 2の画像 2
    • Using a sheet of 150-grit sandpaper, slightly sand away any wood pieces protruding from the damaged area.
  4. How to Fix Chipped Wood Furniture: 手順 4、 3の画像 1 How to Fix Chipped Wood Furniture: 手順 4、 3の画像 2 How to Fix Chipped Wood Furniture: 手順 4、 3の画像 3
    • Apply a generous amount of wood filler to the chipped wood and let it harden completely before continuing with the remaining steps.
    • This part may take a while depending on how much wood filler is applied
    • If the chip/ damage is deeper apply the wood filler in layers and let each layer dry completely before applying the next.
  5. How to Fix Chipped Wood Furniture: 手順 5、 3の画像 1 How to Fix Chipped Wood Furniture: 手順 5、 3の画像 2 How to Fix Chipped Wood Furniture: 手順 5、 3の画像 3
    • While waiting for the wood filler to dry, you may choose to fix the other chips or scratches on the wood that do not require the use of wood filler.
    • Make sure to clean the smaller scratches and slightly sand them using the 150 grit sandpaper.
    • Then use a wood stain of your preferred shade that matches the rest of the wood and carefully fill in the affected areas
  6. How to Fix Chipped Wood Furniture: 手順 6、 3の画像 1 How to Fix Chipped Wood Furniture: 手順 6、 3の画像 2 How to Fix Chipped Wood Furniture: 手順 6、 3の画像 3
    • Once the wood filler completely dries, once again use the same 150-grit sandpaper to sand down the ragged edges of the now hardened wood filler as close to the original shape of the wood.
    • You may additionally use 220-grit sandpaper for a finer/smoother finish.
  7. How to Fix Chipped Wood Furniture: 手順 7、 3の画像 1 How to Fix Chipped Wood Furniture: 手順 7、 3の画像 2 How to Fix Chipped Wood Furniture: 手順 7、 3の画像 3
    • Using a toothbrush or regular paint brush, apply a generous amount of wood stain of your preferred shade.
  8. How to Fix Chipped Wood Furniture: 手順 8、 3の画像 1 How to Fix Chipped Wood Furniture: 手順 8、 3の画像 2 How to Fix Chipped Wood Furniture: 手順 8、 3の画像 3
    • Using a paper towel or cloth, carefully smooth out the wood stain from the previous step while removing any excess stain as well.
  9. How to Fix Chipped Wood Furniture: 手順 9、 2の画像 1 How to Fix Chipped Wood Furniture: 手順 9、 2の画像 2
    • Let the stain dry for at least six hours.
終わりに
The repair guide can be used to fix any type of wooden furniture by making sure you choose the right wood stain. Happy Fixing!
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Anne
メンバー登録日: 05/12/21
193 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G5, Melo-Thaiss Summer 2021 York University, Team S1-G5, Melo-Thaiss Summer 2021人のメンバー
YORK-MELO-THAISS-SU21S1G5
1 メンバー
2のガイドは作成済み
コメント 1 件
Thanks for sharing this informative article with us and i have seen more furniture repair here https://10minutesformom.com/home-improve...
praveen - 返信
コメントを追加
統計データ:
過去 24時間: 32
過去 7 日: 179
過去 30 日: 731
今までの合計 25,347
