メインコンテンツにスキップ
How to Fix Broken Porch Entry Stairs
必要な工具と部品
  1. How to Fix Broken Porch Entry Stairs, Stair treads and risers: 手順 1、 3の画像 1 How to Fix Broken Porch Entry Stairs, Stair treads and risers: 手順 1、 3の画像 2 How to Fix Broken Porch Entry Stairs, Stair treads and risers: 手順 1、 3の画像 3
    • Use a pry bar to remove the pre-existing damaged wood pieces.
    • Start with the riser first.
    • Be mindful of possible rusted screws/nails.
  2. How to Fix Broken Porch Entry Stairs: 手順 2、 3の画像 1 How to Fix Broken Porch Entry Stairs: 手順 2、 3の画像 2 How to Fix Broken Porch Entry Stairs: 手順 2、 3の画像 3
    • Remove the treads on the stairs.
  3. How to Fix Broken Porch Entry Stairs: 手順 3、 2の画像 1 How to Fix Broken Porch Entry Stairs: 手順 3、 2の画像 2
    • Use a measuring tape to measure the foundation where the new steps will be placed.
    • To ensure accurate measurements, make sure to repeat this step twice.
  4. How to Fix Broken Porch Entry Stairs: 手順 4、 3の画像 1 How to Fix Broken Porch Entry Stairs: 手順 4、 3の画像 2 How to Fix Broken Porch Entry Stairs: 手順 4、 3の画像 3
    • Mark your measurements on both ends of your new weather treated wood using a measuring tape and a pencil.
    • For the best results, use a ruler to connect your marks into a straight line.
  5. How to Fix Broken Porch Entry Stairs: 手順 5、 1の画像 1
    • Place the new piece of wood onto the end of a sturdy table.
    • Make sure the marked end is hanging off the edge by at least a foot.
  6. How to Fix Broken Porch Entry Stairs: 手順 6、 1の画像 1
    • Use a circular saw to cut across the straight line marked on the new piece of wood.
    • Make sure the wood is secure by holding the end resting on the table the entire time.
    • Safety glasses should be worn during this step.
  7. How to Fix Broken Porch Entry Stairs: 手順 7、 2の画像 1 How to Fix Broken Porch Entry Stairs: 手順 7、 2の画像 2
    • Place the new piece of wood (riser) on the steps to ensure that it fits.
    • Use a leveler to make sure that it is level.
  8. How to Fix Broken Porch Entry Stairs: 手順 8、 3の画像 1 How to Fix Broken Porch Entry Stairs: 手順 8、 3の画像 2 How to Fix Broken Porch Entry Stairs: 手順 8、 3の画像 3
    • Secure your wood piece (riser) into place using a drill and galvanized screws.
    • Create two pilot holes with the correct drill bit.
    • Secure the wood (riser) into place by drilling 2" galvanized Phillips head screws into the pilot holes.
  9. How to Fix Broken Porch Entry Stairs: 手順 9、 1の画像 1
    • Make sure your wood piece (tread) fits into place and is level.
    • For the most accurate results, it is important to use a large level.
  10. How to Fix Broken Porch Entry Stairs: 手順 10、 3の画像 1 How to Fix Broken Porch Entry Stairs: 手順 10、 3の画像 2 How to Fix Broken Porch Entry Stairs: 手順 10、 3の画像 3
    • Secure your wood piece (tread) into place using a drill and galvanized screws.
    • Create three pilot holes with the correct drill bit.
    • Secure the wood (tread) into place by drilling 2" galvanized Phillips head screws into the pilot holes.
  11. How to Fix Broken Porch Entry Stairs: 手順 11、 1の画像 1
    • Repeat steps 8-10 for the remaining stairs.
    • For the best results, follow this guide thoroughly for each stair.
終わりに
To reassemble your old stairs, follow these instructions in reverse order.
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Kayla Unsworth
メンバー登録日: 01/19/18
240 ポイント
1ガイドが承認済み
チーム
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018 USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018人のメンバー
USFSM-STEWART-S18S1G1
15 メンバー
25のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 32
過去 30 日: 126
今までの合計 8,099
