メインコンテンツにスキップ
How to Fix Bicycle Foam Handlebar Grips
必要な工具と部品
  1. How to Fix Bicycle Foam Handlebar Grips, How to Fix Bicycle Foam Handlebar Grips: 手順 1、 3の画像 1 How to Fix Bicycle Foam Handlebar Grips, How to Fix Bicycle Foam Handlebar Grips: 手順 1、 3の画像 2 How to Fix Bicycle Foam Handlebar Grips, How to Fix Bicycle Foam Handlebar Grips: 手順 1、 3の画像 3
    • Assess the problem area on your bike's handlebars.
  2. How to Fix Bicycle Foam Handlebar Grips: 手順 2、 2の画像 1 How to Fix Bicycle Foam Handlebar Grips: 手順 2、 2の画像 2
    • Lightly sand down the handlebar with the sandpaper.
    • Continue to sand the handlebar until no more residue falls.
  3. How to Fix Bicycle Foam Handlebar Grips: 手順 3、 2の画像 1 How to Fix Bicycle Foam Handlebar Grips: 手順 3、 2の画像 2
    • Boil water in a pot.
    • Once the water reaches boiling temperature (212°F/100°C), dip a rag into the water.
    • Be careful when handling the rag after it has been taken out of the boiling water. Handling the rag too quickly can result in a burn.
    • Take the soaked rag and begin cleaning the handlebar by applying pressure and rubbing in a downwards motion.
  4. How to Fix Bicycle Foam Handlebar Grips: 手順 4、 2の画像 1 How to Fix Bicycle Foam Handlebar Grips: 手順 4、 2の画像 2
    • Press a new, clean rag tightly to the opening of the alcohol bottle.
    • Tip the bottle upside down quickly and soak the rag with the alcohol.
    • Once the rag is soaked, start cleaning the handlebar again. Continue to clean the handlebar until there is no more visible residue coming off.
  5. How to Fix Bicycle Foam Handlebar Grips: 手順 5、 2の画像 1 How to Fix Bicycle Foam Handlebar Grips: 手順 5、 2の画像 2
    • Finally, bring the water to a boil once more.
    • Dip a rag into the water and begin rubbing the handlebar for the last time. Clean vigorously until the handlebar is noticeably smoother and no longer crumbling with residue.
終わりに
Following these steps should result in handlebars that feel brand new!
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Katy Haas
メンバー登録日: 04/28/17
125 ポイント
1ガイドが承認済み
チーム
UC Davis, Team S1-G1, Coad Spring 2017 UC Davis, Team S1-G1, Coad Spring 2017人のメンバー
UCD-COAD-S17S1G1
4 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 18
今までの合計 5,790
