メインコンテンツにスキップ
How to Fix A Crooked Cabinet Door
必要な工具と部品
  1. How to Fix A Crooked Cabinet Door, How to Fix A Crooked Cabinet Door: 手順 1、 1の画像 1
    • Open the cabinet door, and determine where it is misaligned.
  2. How to Fix A Crooked Cabinet Door: 手順 2、 1の画像 1
    • Re-attach the hinge into place.
    • Soft-closing multi-adjustable hinges can snap back into their thickness plates which is the part attached to the inside of the cabinet.
    • Avoid placing your fingers near the thickness plate as its force can cause a painful pinch.
  3. How to Fix A Crooked Cabinet Door: 手順 3、 1の画像 1
    • Hold the hinge firmly against the thickness plate and tighten the screw until the hinge is no longer loose.
    • There are different methods for aligning your cabinet door depending on the screw you tighten and the direction:
    • Side-to-Side Adjustment: To move the door away from the cabinet, screw clockwise. To move the door closer to the cabinet, screw in a counterclockwise motion.
    • Up-Down Adjustment: Screw in a clockwise motion to move the door up. A counterclockwise motion will move the door down.
  4. How to Fix A Crooked Cabinet Door: 手順 4、 1の画像 1
    • The result of the tightened hinge will look as pictured.
  5. How to Fix A Crooked Cabinet Door: 手順 5、 1の画像 1
    • Measure along the top and sides of the cabinet with a balance ruler or standard ruler.
    • The result should look as pictured.
ゴール
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Camrynne Paul
メンバー登録日: 03/19/22
121 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 4-44, Briggs Spring 2022 CSU Los Angeles, Team 4-44, Briggs Spring 2022人のメンバー
CSULA-BRIGGS-S22S4G44
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 66
過去 30 日: 280
今までの合計 7,347
