メインコンテンツにスキップ
How to Fill a Gap with Latex Caulk
必要な工具と部品
  1. How to Fill a Gap with Latex Caulk, How to Fill a Gap with Latex Caulk: 手順 1、 3の画像 1 How to Fill a Gap with Latex Caulk, How to Fill a Gap with Latex Caulk: 手順 1、 3の画像 2 How to Fill a Gap with Latex Caulk, How to Fill a Gap with Latex Caulk: 手順 1、 3の画像 3
    • Clean all surfaces and remove any clutter.
  2. How to Fill a Gap with Latex Caulk: 手順 2、 3の画像 1 How to Fill a Gap with Latex Caulk: 手順 2、 3の画像 2 How to Fill a Gap with Latex Caulk: 手順 2、 3の画像 3
    • Use the latex paint remover spray for the areas that have remaining material along with the gaps. These areas also need to be replaced with new material.
  3. How to Fill a Gap with Latex Caulk: 手順 3、 3の画像 1 How to Fill a Gap with Latex Caulk: 手順 3、 3の画像 2 How to Fill a Gap with Latex Caulk: 手順 3、 3の画像 3
    • Use scissors to cut the head of the caulk tube at a 45 degree angle.
    • This will help to better fill the gaps.
  4. How to Fill a Gap with Latex Caulk: 手順 4、 3の画像 1 How to Fill a Gap with Latex Caulk: 手順 4、 3の画像 2 How to Fill a Gap with Latex Caulk: 手順 4、 3の画像 3
    • Insert the seal punch into the tip of the latex tube to pierce a hole.
  5. How to Fill a Gap with Latex Caulk: 手順 5、 3の画像 1 How to Fill a Gap with Latex Caulk: 手順 5、 3の画像 2 How to Fill a Gap with Latex Caulk: 手順 5、 3の画像 3
    • Pull back the handle of the caulk gun.
    • Place the caulk tube inside it.
    • Twist the metal bar until it is completely inside the caulk tube and the curved handle is on top.
  6. How to Fill a Gap with Latex Caulk: 手順 6、 3の画像 1 How to Fill a Gap with Latex Caulk: 手順 6、 3の画像 2 How to Fill a Gap with Latex Caulk: 手順 6、 3の画像 3
    • Add the latex to the areas you see gaps.
    • After finishing each side, slide your finger along the caulk to push the material inside the gaps.
    • Use a wipe to immediately clean the excess from the filled areas.
  7. How to Fill a Gap with Latex Caulk: 手順 7、 1の画像 1
    • Use latex remover spray to remove any material stuck to your hand.
ゴール
作成者
1人の作成者と共同作成されました。
Ehsan Alagheband
メンバー登録日: 09/16/21
153 ポイント
1ガイドが承認済み
チーム
York University, Team 2-14, O'Regan Fall 2021 York University, Team 2-14, O'Regan Fall 2021人のメンバー
YORK-O'REGAN-F21S2G14
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 14
今までの合計 530
