メインコンテンツにスキップ
How to Factory Reset an AirTag
必要な工具と部品
  1. How to Factory Reset an AirTag, How to Factory Reset an AirTag: 手順 1、 1の画像 1
    • Using one finger press, down on the back of the AirTag.
  2. How to Factory Reset an AirTag: 手順 2、 1の画像 1
    • Twist the back cover counterclockwise.
    • Lift and remove the cover.
  3. How to Factory Reset an AirTag: 手順 3、 1の画像 1
    • Remove the battery using an index finger and thumb.
    • If you need to replace the battery, do so now. The battery type is a CR2032
  4. How to Factory Reset an AirTag: 手順 4、 1の画像 1
    • Place the battery back into the AirTag facing upwards.
    • Press down on the battery with light pressure until you hear a chime.
    • This ringing indicates that the battery is connected.
    • If you do not hear a ringing tone, your battery might need to be replaced.
  5. How to Factory Reset an AirTag: 手順 5、 3の画像 1 How to Factory Reset an AirTag: 手順 5、 3の画像 2 How to Factory Reset an AirTag: 手順 5、 3の画像 3
    • When the chime finishes playing, repeat Step 4 five times by removing the battery, replacing it, and pressing down on the battery until you hear a chime.
    • On the fifth time you will hear a different chime as compared to the four previous times.
  6. How to Factory Reset an AirTag: 手順 6、 2の画像 1 How to Factory Reset an AirTag: 手順 6、 2の画像 2
    • Once the fifth chime is heard the Air Tag has been reset and is ready to be paired.
終わりに
9 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Daniel Barajas
メンバー登録日: 03/20/22
349 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team Z-99, Briggs Spring 2022 CSU Los Angeles, Team Z-99, Briggs Spring 2022人のメンバー
CSULA-BRIGGS-S22SZG99
3 メンバー
5のガイドは作成済み
4 件のコメント
Thank you for sharing this information. I’m investigating this product prior to purchasing.
DonManion - 返信
I believe that using the "Remove" command in Find My app (Items) will reset the AirTag for another person to use. It disconnects it from the Apple ID used to register it. Have tested this.
Of course, if the AirTag is malfunctioning, this battery method should suffice to fully reset it. You will probably want to remove it from the Find My app anyway so new registration can proceed. (I have not tested performing this hard reset and then pairing with my ID while it was still registered.)
David Spalding - 返信
I try and my grandson and both failed to take the tags apart following the instructions where I get them changed?
Jajue - 返信
I've got the same problem. Anyone got a solution?
Peter T -
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 69
過去 30 日: 381
今までの合計 7,661
