メインコンテンツにスキップ
How to Enlarge a Bikini Bottom
必要な工具と部品
  1. How to Enlarge a Bikini Bottom, How to Enlarge a Bikini Bottom: 手順 1、 3の画像 1 How to Enlarge a Bikini Bottom, How to Enlarge a Bikini Bottom: 手順 1、 3の画像 2 How to Enlarge a Bikini Bottom, How to Enlarge a Bikini Bottom: 手順 1、 3の画像 3
    • IMPORTANT: The following steps are only to repair a bikini bottom that is too small in order to make it adjustable to bigger sizes.
    • Use a tape measure to determine the amount of side seam you want to remove so that both sides are the same.
    • Pick the length based on your preference or needs. In this guide, I've removed 50.8 mm.
    • Use sewing scissors to cut 25.4 mm from each side at the seam.
  2. How to Enlarge a Bikini Bottom: 手順 2、 1の画像 1
    • Fully extend the bikini bottom on a flat surface.
  3. How to Enlarge a Bikini Bottom: 手順 3、 3の画像 1 How to Enlarge a Bikini Bottom: 手順 3、 3の画像 2 How to Enlarge a Bikini Bottom: 手順 3、 3の画像 3
    • Pick an elastic and measure around half a meter or 19 inches.
    • Cut the elastic in two halves, the long way.
    • You don't have to use an elastic, you can also use laces, ribbons, or material from old bikinis.
  4. How to Enlarge a Bikini Bottom: 手順 4、 3の画像 1 How to Enlarge a Bikini Bottom: 手順 4、 3の画像 2 How to Enlarge a Bikini Bottom: 手順 4、 3の画像 3
    • Basic sewing knowledge is not required, but preferred.
    • Pay close attention when handling the sewing needle. Keep away from eyes or children.
    • To begin, sew the elastic directly to the bikini on the interior of the suit at all four sides with the the loose ends facing out.
    • The last picture shows how your bikini should look after sewing the elastic onto the fabric.
  5. How to Enlarge a Bikini Bottom: 手順 5、 3の画像 1 How to Enlarge a Bikini Bottom: 手順 5、 3の画像 2 How to Enlarge a Bikini Bottom: 手順 5、 3の画像 3
    • To create a ruched look for the bikini and to finish the seam where you've sewn the elastic onto the fabric, sew between the middle of the fabric.
    • Repeat this step four times on each side of the bikini, two on the right and two on the left.
  6. How to Enlarge a Bikini Bottom: 手順 6、 1の画像 1
    • Your final product should look like this. As a result, your bikini will now have two ties in each side of your hip where it can be tightened or loosened as you wish.
    • If your straps seem a little loose you can continue to sew over the fabric to tighten it a bit more.
終わりに
If by the end of this guide your swimsuit is not yet of your liking you can add more elastic to your bikini or choose another style.
作成者
2人の作成者と共同で作成されました。
Arianna L. Rodriguez Hernandez
メンバー登録日: 03/18/22
133 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 27
過去 30 日: 122
今までの合計 2,037
