この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
It's always a good idea to disconnect the battery before working on your vehicle's ignition system or other electrical components. (If you need to fully remove or replace the battery, follow this guide instead.)
This guide uses a Toyota Corolla to demonstrate the procedure, which is similar for most motor vehicles.
Note: Disconnecting your battery may erase certain stored settings, such as radio/navigation presets and power window memory. Consult your owner's manual for details.
必要な工具と部品
Make sure the transmission is in Park (or first gear if you have a manual gearbox) and that the parking brake is engaged.
In addition to being dirty, the battery contains corrosive agents and may release flammable gases.
Gloves can also help protect you from an unpleasant shock if you accidentally mishandle the battery.
If you're not sure, simply continue reading.
Pull the hood release lever. It's usually located inside the car, near the steering wheel.
4 の人々がこのガイドを完成させました。
