メインコンテンツにスキップ
How to Disassemble an OXO Container Lid for Cleaning
必要な工具と部品
  1. How to Disassemble an OXO Container Lid for Cleaning, How to Disassemble an OXO Container Lid for Cleaning: 手順 1、 2の画像 1 How to Disassemble an OXO Container Lid for Cleaning, How to Disassemble an OXO Container Lid for Cleaning: 手順 1、 2の画像 2
    • Twist the bottom piece off by following the directions displayed on the lid.
    • Once inside, remove the outer layer seal from the lid by pulling it straight up.
  2. How to Disassemble an OXO Container Lid for Cleaning: 手順 2、 3の画像 1 How to Disassemble an OXO Container Lid for Cleaning: 手順 2、 3の画像 2 How to Disassemble an OXO Container Lid for Cleaning: 手順 2、 3の画像 3
    • Flip the lid so the button faces up. Then remove the button from the base of the lid.
    • This requires more added force.
    • Separate the interior prongs.
  3. How to Disassemble an OXO Container Lid for Cleaning: 手順 3、 2の画像 1 How to Disassemble an OXO Container Lid for Cleaning: 手順 3、 2の画像 2
    • After separating the prongs, the spring and the circular spring cap will separate from the square frame with little force.
    • With some force, remove the two prongs from the base of the lid by snapping them out of the bracket. Be careful not to break the bracket's small prongs.
    • The disassembled parts can now be cleaned with warm, soapy water.
  4. How to Disassemble an OXO Container Lid for Cleaning: 手順 4、 2の画像 1 How to Disassemble an OXO Container Lid for Cleaning: 手順 4、 2の画像 2
    • To reassemble the lid, start by connecting the outer layer piece with the base piece. Grooves in the parts will only allow them to be connected in the correct way.
    • Place the spring in the center of the lid within the circular outline.
  5. How to Disassemble an OXO Container Lid for Cleaning: 手順 5、 1の画像 1
    • Take the small interior circle and place it on top of the spring.
    • Use force to push this piece down. Make sure the slots align.
    • This piece will not stay in place on its own. Flip the lid over and keep it on a flat surface to prevent the spring from releasing.
  6. How to Disassemble an OXO Container Lid for Cleaning: 手順 6、 2の画像 1 How to Disassemble an OXO Container Lid for Cleaning: 手順 6、 2の画像 2
    • Reattach the two prongs to the lid.
    • Intertwine the two prongs together.
    • The spring should now be firmly held in place.
  7. How to Disassemble an OXO Container Lid for Cleaning: 手順 7、 2の画像 1 How to Disassemble an OXO Container Lid for Cleaning: 手順 7、 2の画像 2
    • Twist the bottom piece back on the lid.
    • Reattach the button to the center of the lid.
ゴール
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Lorna Lauro
メンバー登録日: 04/20/22
187 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 7-77, Harris Spring 2022 CSU Los Angeles, Team 7-77, Harris Spring 2022人のメンバー
CSULA-HARRIS-S22S7G77
1 メンバー
1のガイドは作成済み
コメント 1 件
Excellent guide, a set I got came with the metal pins of the prongs unseated from their holes, causing the lid to operate incorrectly. I was able to re-seat them and get the lid working with the help of this.
Stefan Rust - 返信
コメントを追加
統計データ:
過去 24時間: 13
過去 7 日: 56
過去 30 日: 304
今までの合計 12,557
