メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How to Disable Pop-Up Blockers in Safari, Chrome, and Firefox on Mac
  1. How to Disable Pop-Up Blockers in Safari, Chrome, and Firefox on Mac, Disable pop-up blocker in Safari: 手順 1、 3の画像 1 How to Disable Pop-Up Blockers in Safari, Chrome, and Firefox on Mac, Disable pop-up blocker in Safari: 手順 1、 3の画像 2 How to Disable Pop-Up Blockers in Safari, Chrome, and Firefox on Mac, Disable pop-up blocker in Safari: 手順 1、 3の画像 3
    • Launch Safari, then open the Safari menu and select Settings (or Preferences, depending on your macOS release).
    • In the settings panel, switch to the Websites section and choose Pop-up Windows from the list on the left.
    • Locate the website you want to adjust and change its permission to Allow, which lets that site open pop-up windows when needed.
    • To allow pop-ups for every site, scroll to the bottom of the Pop-up Windows settings and change the When visiting other websites option to Allow. Safari doesn’t label this as a “pop-up blocker,” but this is the control that governs global pop-up behavior.
    FixBotに聞いてみる
    コメントを追加
  2. How to Disable Pop-Up Blockers in Safari, Chrome, and Firefox on Mac, Turn off pop-up blocker in Chrome on Mac: 手順 2、 3の画像 1 How to Disable Pop-Up Blockers in Safari, Chrome, and Firefox on Mac, Turn off pop-up blocker in Chrome on Mac: 手順 2、 3の画像 2 How to Disable Pop-Up Blockers in Safari, Chrome, and Firefox on Mac, Turn off pop-up blocker in Chrome on Mac: 手順 2、 3の画像 3
    • Open Google Chrome, then click the three-dot menu in the upper-right corner of the window and choose Settings from the list.
    • Go to the Privacy and security section in the settings panel.
    • Scroll through the page and open the Site settings section.
    • Select the Pop-ups and redirects option from the list.
    • Choose the setting labeled Sites can send pop-ups and use redirects to allow pop-ups everywhere and disable the global blocking behavior.
    • If you want to allow pop-ups for only one site while keeping the global setting unchanged, click Add in the Allowed to send pop-ups and use redirects section, enter the site’s URL, and confirm by selecting Add in the dialog window.
    • The site you added will appear in the exceptions list, and Chrome will allow it to display pop-ups even if blocking is enabled for all other websites.
    FixBotに聞いてみる
    コメントを追加
  3. How to Disable Pop-Up Blockers in Safari, Chrome, and Firefox on Mac, Turn Off the Pop-Up Blocker in Firefox on Mac: 手順 3、 3の画像 1 How to Disable Pop-Up Blockers in Safari, Chrome, and Firefox on Mac, Turn Off the Pop-Up Blocker in Firefox on Mac: 手順 3、 3の画像 2 How to Disable Pop-Up Blockers in Safari, Chrome, and Firefox on Mac, Turn Off the Pop-Up Blocker in Firefox on Mac: 手順 3、 3の画像 3
    • Launch Firefox, then open the three-line menu in the upper-right corner and choose Settings from the options.
    • Choose Privacy & Security in the sidebar, scroll down to the Permissions section, and uncheck the box next to the Block pop-up windows option as shown below.
    • If you want to keep pop-up blocking enabled but make an exception for a trusted site, click Exceptions next to the Block pop-up windows setting. Enter the site’s URL, choose Allow, and finish by selecting Save Changes.
    • The site you added will appear in the exceptions list with its status set to Allow, and you can remove it from this list at any time if you no longer want to permit pop-ups.
    FixBotに聞いてみる
    コメントを追加
終わりに
Pop-up blockers are essential for maintaining a secure browsing environment, but like any automated control, they can occasionally overreach. When you’re confident that a site is legitimate, such as your bank, employer portal, or a verified service provider, temporarily turning off the blocker can help restore full functionality.
Always re-enable it once you’re done. A properly managed pop-up policy strikes a balance between usability and protection, ensuring your Mac remains secure without disrupting legitimate workflows.
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Alex Vakulov
メンバー登録日: 03/08/21
409 ポイント
2のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 10
過去 7 日: 127
過去 30 日: 536
今までの合計 2,133
