はじめに
Are you wondering why your Nespresso coffee is tasting off and doesn’t have that sufficient taste? Use this guide to learn how to descale your Nespresso VertuoPlus machine in an easy few steps.
Descaling your coffee machine is ultimately cleaning and stripping any excess dirt that has built up on the machine’s surface which could potentially cause your coffee machine to stop functioning properly and result in bad-tasting coffee.
Before using this guide, make sure you have the Nespresso descaling kit. Any other type of cleaning solution used in the machine could potentially break the machine.
必要な工具と部品
Turn the machine on by pressing the button with a coffee mug logo.
39 の人々がこのガイドを完成させました。
8 件のコメント
When I hit the button to begin the descaling process, the orange light flashes for a few seconds then I get a red ring and the machine stops
I usually require six envelopes to descale (six times). We have very hard water where we live. Keep repeating process. Once machine has descaled enough, it will go back to green. Persistence wins.
perchè pur funzionante si accende la spia circolare di colore per metà rossa e metà verde?
Devi fare la decalcificazione ti da ancora la possibilità di usarla ma per un breve periodo
Perché dopo aver fatto la decalcificazione compare ancora la spia metà rossa e metà verde?
