はじめに
If used regularly, water minerals can build up over time in the tank and tubes of a coffeemaker. If left unattended, this buildup can cause clog, poor tasting coffee, and can also lead to bacteria and mold growing inside of the machine. This guide will show you how to clean out the interior of a Keurig K-Mini using a mixture of water and white-vinegar.
必要な工具と部品
Rinse and empty the water reservoir.
Make sure no k-cup is in the machine.
Depending on how often you use your device, you should repeat this procedure about once every 3-6 months to maintain good tasting coffee.
