メインコンテンツにスキップ
How to Decrease the Bicep of a Sleeve
必要な工具と部品
  1. How to Decrease the Bicep of a Sleeve, How to Decrease the Bicep of a Sleeve: 手順 1、 3の画像 1 How to Decrease the Bicep of a Sleeve, How to Decrease the Bicep of a Sleeve: 手順 1、 3の画像 2 How to Decrease the Bicep of a Sleeve, How to Decrease the Bicep of a Sleeve: 手順 1、 3の画像 3
    • Flip your shirt inside out.
    • The raw edges should be on the outside.
  2. How to Decrease the Bicep of a Sleeve: 手順 2、 3の画像 1 How to Decrease the Bicep of a Sleeve: 手順 2、 3の画像 2 How to Decrease the Bicep of a Sleeve: 手順 2、 3の画像 3
    • Use a measuring tape to measure your desired width from the top point of the shoulder down to the seam of the shoulder.
    • Mark the bottom point of your measurement with a fabric pen or tailor's chalk.
  3. How to Decrease the Bicep of a Sleeve: 手順 3、 3の画像 1 How to Decrease the Bicep of a Sleeve: 手順 3、 3の画像 2 How to Decrease the Bicep of a Sleeve: 手順 3、 3の画像 3
    • Use a fabric marker or tailor's chalk to draw a line from the marking, ensuring it aligns with the rest of the sleeve.
    • It should align with the sleeve at the cuff.
    • Draw another line from the marking, extending down to align with the side of the body of the shirt.
  4. How to Decrease the Bicep of a Sleeve: 手順 4、 3の画像 1 How to Decrease the Bicep of a Sleeve: 手順 4、 3の画像 2 How to Decrease the Bicep of a Sleeve: 手順 4、 3の画像 3
    • Use straight pins to pin the sleeve across the lines you drew.
    • Push the pin through the top and push it back through the bottom of the sleeve.
    • Place a pin every inch across the lines.
  5. How to Decrease the Bicep of a Sleeve: 手順 5、 3の画像 1 How to Decrease the Bicep of a Sleeve: 手順 5、 3の画像 2 How to Decrease the Bicep of a Sleeve: 手順 5、 3の画像 3
    • Using a sewing machine, sew across the pinned lines with a straight stitch.
    • Be sure to backstitch at the start and end of your stitch.
  6. How to Decrease the Bicep of a Sleeve: 手順 6、 3の画像 1 How to Decrease the Bicep of a Sleeve: 手順 6、 3の画像 2 How to Decrease the Bicep of a Sleeve: 手順 6、 3の画像 3
    • Use scissors to cut off the excess fabric.
    • Leave a seam allowance of 6.4 mm.
  7. How to Decrease the Bicep of a Sleeve: 手順 7、 1の画像 1
    • Measure again to see if you reached your desired width.
終わりに
Now that you have finished your fix, go ahead and try on that perfect-fitting shirt. Thank you for picking this fast fix guide!
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Elliot T
メンバー登録日: 09/27/23
145 ポイント
1ガイドが承認済み
チーム
University of Arizona, Team 6-3, Cools Stephens Fall 2023 University of Arizona, Team 6-3, Cools Stephens Fall 2023人のメンバー
ARIZONA-COOLS STEPHENS-F23S6G3
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 22
今までの合計 101
