メインコンテンツにスキップ
How to Correctly clean corrosion from a MacBook Pro logic board.
必要な工具と部品
    • Your first step is to remove your MacBooks main Logic Board, this process will very from model to model and the guides are readily available on iFixit. For this example we will be disassembling an A1502 MacBook Pro w/ Force Touch.
  1. How to Correctly clean corrosion from a MacBook Pro logic board., Remove the heat sink and thermal paste.: 手順 2、 2の画像 1 How to Correctly clean corrosion from a MacBook Pro logic board., Remove the heat sink and thermal paste.: 手順 2、 2の画像 2
    • Next, we are going to remove the heat sink and thermal paste. Again this step will very slightly from model to model but is important to ensure proper cleaning.
  2. How to Correctly clean corrosion from a MacBook Pro logic board., Clean the obvious corrosion.: 手順 3、 1の画像 1
    • Place the MLB on a lint free towel and begin to carefully remove any visible corrosion with a tooth brush and 99% Isopropyl alcohol. AT this point I would take pictures of the affected areas before cleaning so you have an idea of where to start diagnostics once the board has been cleaned.
    • Placing the board in an ultrasonic bath for 15 minutes at 40c with some type of electronics safe detergent will ensure that corrosion that is not visible to the naked eye will be removed. Electricity is the catalyst for corrosion, even a small amount left untreated can come back to bite you. In my opinion a toothbrush and alcohol alone is risky.
  3. How to Correctly clean corrosion from a MacBook Pro logic board., Rinse and allow to dry.: 手順 5、 1の画像 1
    • Place the logic board in a shallow bath of 99% alcohol for a few minutes to displace the water from the ultrasonic bath. Use canned air or and electric air gun to blow the board dry.
  4. How to Correctly clean corrosion from a MacBook Pro logic board., Inspection, Inspection and more Inspection.: 手順 6、 1の画像 1
    • If you have a stereo microscope you should go over the board to look for damaged components or broken solder joints. If no microscope is available this would be a good time to loosely reassemble the unit and see if you have a good result. If the unit has visible issues board level you may want to consider finding a professional repair option.
    • Like we said in the beginning, getting the MLB up and running is likely one of several steps required to restore a MacBook after a liquid spill. We hope this guide was helpful, Good Luck.
終わりに
13 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Forza Vale
メンバー登録日: 02/09/17
3,369 ポイント
6のガイドは作成済み
チーム
triomacrepair.com triomacrepair.com人のメンバー
Business
1 メンバー
18のガイドは作成済み
3 件のコメント
The new mbpro has the logic board completely attached to the case along with the battery. Would it be possible to put submerge the entire thing in ultrasonic bath? or is that just going to destroy it?
Calvin Chong - 返信
I have read on a Mac repair company web page that logic boards from 2015 MacBook Pros onwards should not be put through ultrasonic baths as it damages the CPU. Is there any truth/logic to this?
nick - 返信
Similar question as the other 2 comments: I was wondering if this worked for the M1 14" 2021 laptops? I was concerned about the storage and stuff on the logic board itself and if the ultrasonic bath could ruin those? Also, do you know the dimensions of the logic board (part number 661-21276) itself and if 6L with a basket would an appropriate bath size? What temperature did you use in your bath? I assume the 40 is in regards to khz or was it celsius? Any suggestions on bath brand/model and detergent are also welcome!
cposeria - 返信
コメントを追加
統計データ:
過去 24時間: 12
過去 7 日: 63
過去 30 日: 287
今までの合計 50,191
