メインコンテンツにスキップ
Convert a 360 (Fat) hard drive into a 360 S hard drive
必要な工具と部品
  1. Convert a 360 (Fat) hard drive into a 360 S hard drive, Remove the bottom screws: 手順 1、 3の画像 1 Convert a 360 (Fat) hard drive into a 360 S hard drive, Remove the bottom screws: 手順 1、 3の画像 2 Convert a 360 (Fat) hard drive into a 360 S hard drive, Remove the bottom screws: 手順 1、 3の画像 3
    • Buy the drive at a cost you can afford to eat. This will void any warranties offered.
    • Remove the 3 screws from the bottom of the drive. Use a T6 Torx driver.
    • Remove the warranty seal and final screw. Use a T6 Torx driver.
  2. Convert a 360 (Fat) hard drive into a 360 S hard drive, Disassembly tip: 手順 2、 1の画像 1
    • If the drive is difficult to open and you are opening it to put the drive into a later Xbox 360 with no intention to preserve the enclosure, a screwdriver or pry tool can help.
    • If you are opening it to replace the drive inside for an original console, it is best to use a plastic pry tool instead. While a screwdriver "works" it will likely mar the enclosure.
  3. Convert a 360 (Fat) hard drive into a 360 S hard drive, Open the drive: 手順 3、 3の画像 1 Convert a 360 (Fat) hard drive into a 360 S hard drive, Open the drive: 手順 3、 3の画像 2 Convert a 360 (Fat) hard drive into a 360 S hard drive, Open the drive: 手順 3、 3の画像 3
    • If you are taking the enclosure apart for the bare drive, less caution is needed.
    • After removing the 4 bottom screws, remove the top cover. Remove the spring and locking tab before removing the drive cage.
    • Remove the drive cage from the drive enclosure. If the drive has never been opened, additonal force may be required.
  4. Convert a 360 (Fat) hard drive into a 360 S hard drive, Disconnect and remove the hard drive: 手順 4、 3の画像 1 Convert a 360 (Fat) hard drive into a 360 S hard drive, Disconnect and remove the hard drive: 手順 4、 3の画像 2 Convert a 360 (Fat) hard drive into a 360 S hard drive, Disconnect and remove the hard drive: 手順 4、 3の画像 3
    • Remove the four T10 Torx screws securing the hard drive.
    • After removing the screws, slide the top cover off and disconnect the drive.
    • Disconnect the hard drive and remove it from the enclosure.
  5. Convert a 360 (Fat) hard drive into a 360 S hard drive, Install the hard drive into the new enclosure: 手順 5、 3の画像 1 Convert a 360 (Fat) hard drive into a 360 S hard drive, Install the hard drive into the new enclosure: 手順 5、 3の画像 2 Convert a 360 (Fat) hard drive into a 360 S hard drive, Install the hard drive into the new enclosure: 手順 5、 3の画像 3
    • If you do not use an official hard drive, you will need a WD hard drive, the Xbox hard drive sector security file and HDDhackr to partition the drive. Partition 2 must be restored manually.
    • After removing the drive from the old enclosure, open the new enclosure.
    • Put the drive in the enclosure label side up. Space may need to be added for 7mm drives.
    • Close the enclosure and install it in your console.
ゴール
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Nick
メンバー登録日: 11/10/09
88,752 ポイント
49のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,521のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 54
今までの合計 3,464
