メインコンテンツにスキップ
How to Clear a blocked, or clogged sink
  1. How to Clear a blocked, or clogged sink, How to Clear a blocked, or clogged sink: 手順 1、 1の画像 1
    • When you first go to clear your sink, you should check how the pipes are connected.
  2. How to Clear a blocked, or clogged sink: 手順 2、 1の画像 1
    • If your piping looks like the photo, you won't need tools to make this fix.
    • You can easily remove these pipes by twisting them off at the brackets.
  3. How to Clear a blocked, or clogged sink: 手順 3、 2の画像 1 How to Clear a blocked, or clogged sink: 手順 3、 2の画像 2
    • Twist the higher bracket until it comes undone.
  4. How to Clear a blocked, or clogged sink: 手順 4、 1の画像 1
    • Twist the lower bracket until it also comes undone.
    • Water and other liquids will pour out of the brackets so hold the pipe tightly to avoid making a mess.
  5. How to Clear a blocked, or clogged sink: 手順 5、 1の画像 1
    • Gently remove the pipe and find somewhere to dump out the contents that caused it to be clogged.
    • The pipe will be full of water and whatever is stuck inside. Any large obstructions or other blockages may fall out.
  6. How to Clear a blocked, or clogged sink: 手順 6、 1の画像 1
    • Clear out the gunk, obstructions, and any other objects in the pipe so that your sink drains properly.
  7. How to Clear a blocked, or clogged sink: 手順 7、 1の画像 1
    • Repeat the steps in reverse to put it back together again.
    • The blockage should now be removed and the sink should be draining properly.
終わりに
Your sink should now be free of obstructions or clogs in the pipes.
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Elijah Santiago
メンバー登録日: 09/18/15
196 ポイント
1ガイドが承認済み
チーム
Pasco Hernando, Team 5-1, Prince Fall 2015 Pasco Hernando, Team 5-1, Prince Fall 2015人のメンバー
PHSC-PRINCE-F15S5G1
1 メンバー
1のガイドは作成済み
コメント 1 件
Smalll repairs can be done on a diy basis, but if drain clogging a regular problem the best solution would be to turn to professional pipe cleaning and restoration. i.e. pipe rehabilitation.
Kanserwis Sp. z o.o - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 24
今までの合計 2,121
