メインコンテンツにスキップ
How to Clean the Keurig K75 Platinum Brewing System Needle
必要な工具と部品
  1. How to Clean the Keurig K75 Platinum Brewing System Needle, How to Clean the Keurig K75 Platinum Brewing System Needle: 手順 1、 1の画像 1
    • Before needle repair, make sure the brewer is disconnected from any power outlet.
    • Lift the handle to open the top of the brewer.
    • There are two sharp needles that puncture the K-Cup pack. One is above the K-Cup holder and the other is in the bottom of the holder. Be careful when cleaning the top needle.
  2. How to Clean the Keurig K75 Platinum Brewing System Needle: 手順 2、 1の画像 1
    • Bend a paperclip to create a vertical metal piece. This is used to clean the top needle.
  3. How to Clean the Keurig K75 Platinum Brewing System Needle: 手順 3、 1の画像 1
    • Insert a paper clip into the exit needle to loosen the debris and push it out.
    • Repeat this action until the debris is cleared from the top needle.
    • All external pieces of the brewer are dishwasher safe.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Alexander Vo
メンバー登録日: 01/11/13
94 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 20-2, Maness Winter 2013 Cal Poly, Team 20-2, Maness Winter 2013人のメンバー
CPSU-MANESS-W13S20G2
4 メンバー
6のガイドは作成済み
9 件のコメント
must be something else on mine. i have cleaned out with paper clip 3 times and still no water comes out.
jjthdj - 返信
try descaling it
marymckercher -
Worked great for mine just now. I picked up a used B20 Platinum at a Garage Sale yesterday for only $10 super easy to clean needle & now it works great!! Thanks OP!!
ronald944 - 返信
My husband keeps wanting to buy me something new every time the old one doesn't work, well I am old fashioned and will do anything I can to save money. Thank goodness this worked than you so much.
Wendy Clark - 返信
How about the needle at the bottom of the holder?
tahoejb - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 9
過去 30 日: 37
今までの合計 21,970
