メインコンテンツにスキップ
How to Clean the InFocus X2 Lamp Housing Screens
必要な工具と部品
  1. How to Clean the InFocus X2 Lamp Housing Screens, Open the Lamp Door: 手順 1、 3の画像 1 How to Clean the InFocus X2 Lamp Housing Screens, Open the Lamp Door: 手順 1、 3の画像 2 How to Clean the InFocus X2 Lamp Housing Screens, Open the Lamp Door: 手順 1、 3の画像 3
    • Be sure that the projector is turned off, unplugged, and has cooled for at least 30 seconds.
    • Insert the Jimmy into one of the two notches on the lamp door's top edge.
    • Then use light force on the Jimmy to pry the latch away from the door.
    • If necessary, insert the Jimmy into the second latch and separate it from the projector.
    • Remove the door away from the projector by hand.
  2. How to Clean the InFocus X2 Lamp Housing Screens, Disconnect the Lamp: 手順 2、 3の画像 1 How to Clean the InFocus X2 Lamp Housing Screens, Disconnect the Lamp: 手順 2、 3の画像 2 How to Clean the InFocus X2 Lamp Housing Screens, Disconnect the Lamp: 手順 2、 3の画像 3
    • Gently disconnect the lamp from the projector by using your thumb and forefinger to pinch on the white tab on the plug.
    • Then pull the plug away from the projector.
  3. How to Clean the InFocus X2 Lamp Housing Screens, Unscrew the Lamp from the Projector: 手順 3、 3の画像 1 How to Clean the InFocus X2 Lamp Housing Screens, Unscrew the Lamp from the Projector: 手順 3、 3の画像 2 How to Clean the InFocus X2 Lamp Housing Screens, Unscrew the Lamp from the Projector: 手順 3、 3の画像 3
    • Use a Phillips #4 screwdriver or driver with the Phillips #4 head to unscrew the two 0.6 mm diameter brass screws from the lamp's housing.
    • For the lower screw, ensure it remains in the hole in the lamp assembly and it does not fall into the projector. If it falls in the projector, use a magnetized screw bit or a small magnet to pick it up and remove it.
  4. How to Clean the InFocus X2 Lamp Housing Screens, Remove the Old Lamp: 手順 4、 1の画像 1
    • Pull on the bottom plastic tab and remove the lamp by hand.
  5. How to Clean the InFocus X2 Lamp Housing Screens, Insert the New Lamp: 手順 5、 1の画像 1
    • Insert the replacement lamp into the projector.
  6. How to Clean the InFocus X2 Lamp Housing Screens, Cleaning the Dirty Screens: 手順 6、 2の画像 1 How to Clean the InFocus X2 Lamp Housing Screens, Cleaning the Dirty Screens: 手順 6、 2の画像 2
    • Use a vacuum cleaner to gently suck up the dust on the front and the back Lamp Housing screens.
終わりに
添付文書
作成者
1人の作成者と共同作成されました。
Paulina Duarte
メンバー登録日: 09/19/13
553 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team 1-3, Gulbrandsen Fall 2013 UMass Dartmouth, Team 1-3, Gulbrandsen Fall 2013人のメンバー
UMASSD-GULBRANDSEN-F13S1G3
3 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 6
今までの合計 246
