メインコンテンツにスキップ
How to Clean the Condenser Coils in your WRS315SDHW Refrigerator
必要な工具と部品
  1. How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Safety precautions: 手順 1、 1の画像 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Unfasten the rear panel: 手順 2、 3の画像 1 How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Unfasten the rear panel: 手順 2、 3の画像 2 How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Unfasten the rear panel: 手順 2、 3の画像 3
    • Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the seven 16.2 mm-long screws securing the rear panel.
    • Use a 1/4 inch socket wrench to loosen the screw securing the water hose enough for the rear panel to freely move.
  3. How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Remove the rear panel: 手順 3、 3の画像 1 How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Remove the rear panel: 手順 3、 3の画像 2 How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Remove the rear panel: 手順 3、 3の画像 3
    • Pull the rear panel off the chassis to remove it.
  4. How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Open the doors: 手順 4、 3の画像 1 How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Open the doors: 手順 4、 3の画像 2 How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Open the doors: 手順 4、 3の画像 3
    • Depending on your repair, open one or both doors.
  5. How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Unfasten the front panel: 手順 5、 3の画像 1 How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Unfasten the front panel: 手順 5、 3の画像 2 How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Unfasten the front panel: 手順 5、 3の画像 3
    • Use a Phillips driver to remove the two 15.2 mm-long screws securing the front panel.
  6. How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Remove the front panel: 手順 6、 3の画像 1 How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Remove the front panel: 手順 6、 3の画像 2 How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Remove the front panel: 手順 6、 3の画像 3
    • Pull the front panel straight off the chassis and remove it.
    • You may have to slightly open the water filter door to remove the front panel completely.
  7. How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Vacuum the condenser coils: 手順 7、 2の画像 1 How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Vacuum the condenser coils: 手順 7、 2の画像 2
    • Vacuum or brush any dust or debris clinging to the black condenser coils.
終わりに
Repair didn’t go as planned? Ask our Answers community for help.
作成者
2人の作成者と共同で作成されました。
nicO
メンバー登録日: 04/14/15
15,927 ポイント
89のガイドは作成済み
チーム
Global Fixers Global Fixers人のメンバー
Community
45 メンバー
702のガイドは作成済み
0 Guide Comments
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 184
