はじめに
The guide will teach you how to take apart, sharpen, and reassemble a Wahl hair clipper. It is recommended to clean and sharpen your clipper every 3 or 4 uses.
必要な工具と部品
Take your Philips head screwdriver and loosen the set screws by turning them left. This will allow you to separate the blades from your clipper.
Fully immerse and soak your blade in 90% isopropyl alcohol to remove any rust that might be present. The blade should soak a minimum of 5 minutes.
Isopropyl alcohol does NOT remove rust.
Weirder Al - 返信
That's right. IPA will clean oils, dirt and germs, but not rust. In fact it can encourage rust. If you need remove rust from your clippers, use something like "Evaporust"
Joe -
Run your blade left and right in a horizontal direction across a Whetstone honing stone. First on the coarse side to sharpen the blade then on the finishing side to smooth out the blade.
No good choice of sharpening stone. This kind of stone is too soft and too coarse even on called “fine grit” side. Softness of stone lead to distortion of flatness of the blade which is critical. Must be sharpened both blades simultaneously. Best way is to use flat (grinded by surface grinder) cast iron plate and lapping compounds 600 and 800 grit sequentially. Also could be used so called “reamer stones”, but usually they are too small to do this job.
vladintool - 返信
@vladintool How do you sharpen both blades simultaneously? Leave them coupled on top of one another and sharpen like that? Or decouple and sharpen side by side?
For anyone else wondering, a lapping compound is: a grease mix abrasive for cutting, smoothing and finishing of metal surfaces and for the precision mating of metal parts.CantBelieveIHadtoMakeAnAccount, You should not leave them coupled. Decouple them and sharpen side by side.
Rinse the honing stone under water and rub the stone back and forth the same direction you used to sharpen your blade. This will clean your stone and remove any debris.
Back and forth in same direction?? Contradictory instructions. You either do back and forth. Or, in same direction. Which is it?
TT nNaples - 返信
Back and forth in the same direction you used to sharpen them. Meaning in a parallel direction as before. Not perpendicular. It makes perfect sense.
Place your blades back into position and insert your set screws into the proper holes. Take your Philips screwdriver and turn the screws to the right until you feel them completely tighten. Be careful to line up your blades correctly.
How do you align the blades? Seems like a pretty important part of the procedure.
Your clippers are ready for use. Plug them in to let them run for a few moments before your first use.
17 の人々がこのガイドを完成させました。
8 件のコメント
Much more easily said than done. I am extremely mechanically orientated and have tried three times to sharpen them. They are almost useless (Wahl animal Pro Series) after only two cuts.
Barry, read my comment to the step 5 - you’ll find how to do it correct.
My shaver after popping the head off to clean stop cutting.what steps can I take to fix this problem?
How do I reassemble the clippers?
Wahl CT12 5GG used once to trim my beard. Next it does not cut at all. I cleaned and oiled it. Left it few days then I hoped it will do the job,regretfully it's running fine but not cutting at all.
My daughter lost the receipt from Asda and without the receipt nothing can be done!!!!?
Kk, did that & my blade cane out in 2 separate pieces. How do I put back together
Michele Sawyer - 返信
Took apart to clean & sharpen. Came out in 2 separate pieces, how do I put back together?
Michele Sawyer - 返信
