メインコンテンツにスキップ
How to Clean and Apply Thermal Compound
必要な工具と部品
  1. How to Clean and Apply Thermal Compound, How to Clean and Apply Thermal Compound: 手順 1、 1の画像 1
    • Saturate a cotton swab with isopropyl alcohol, and remove the thermal compound from the thermal plates on your component using gentle circular motions.
    • As the cotton swab becomes saturated with thermal compound, discard and continue with a freshly dipped cotton swab. The compound plate is clean when the cotton swabs come away clean.
  2. How to Clean and Apply Thermal Compound: 手順 2、 2の画像 1 How to Clean and Apply Thermal Compound: 手順 2、 2の画像 2
    • Repeat the same cleaning process from the previous step on the matching thermal plates on the motherboard.
    • Avoid touching the thermal compound areas once they are clean. Dirt or oil on either surface can disrupt cooling performance and lead to overheating or thermal throttling.
  3. How to Clean and Apply Thermal Compound: 手順 3、 2の画像 1 How to Clean and Apply Thermal Compound: 手順 3、 2の画像 2
    この手順で使用する道具:
    Plastic Cards
    $2.99
    購入する
    • Apply a small amount of thermal compound, about the size of a grain of rice, on the corner of each the cleaned thermal plates on the motherboard.
    • Using a clean plastic card, carefully spread the thermal compound evenly over the surfaces of each thermal plate.
    • You need to clean the thermal plates on both the component and the motherboard, but you only need to apply thermal paste on the motherboard thermal plates.
    • Avoid applying too much or too little thermal compound, as it can impede crucial heat transfer. Once spread, the compound should be about as thick as a single sheet of paper.
  4. How to Clean and Apply Thermal Compound: 手順 4、 1の画像 1
    • Gently re-seat your component, making sure that the thermal plates align correctly.
終わりに
Please refer to the previous guide in order to reassemble your device.
4 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Reina Godeck
メンバー登録日: 10/16/17
741 ポイント
5のガイドは作成済み
チーム
UW Tacoma, Team S3-G5, Liner Fall 2017 UW Tacoma, Team S3-G5, Liner Fall 2017人のメンバー
UWT-LINER-F17S3G5
4 メンバー
18のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 11
今までの合計 2,224
