メインコンテンツにスキップ
How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter
必要な工具と部品
  1. How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter, How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: 手順 1、 2の画像 1 How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter, How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: 手順 1、 2の画像 2
    • Turn off the air conditioner unit manually or with the remote control.
    • Unplug the A/C unit from its power source.
  2. How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: 手順 2、 2の画像 1 How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: 手順 2、 2の画像 2
    • Place your hands on the opposite sides of the air conditioner and unclip the grille from the unit.
  3. How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: 手順 3、 3の画像 1 How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: 手順 3、 3の画像 2 How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: 手順 3、 3の画像 3
    • Gently grab the front grille and place it on the ground or table.
    • Use your hands to pull the filter out of the unit
  4. How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: 手順 4、 2の画像 1 How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: 手順 4、 2の画像 2
    • Carry the filter to a faucet and flush with water to eliminate dust particles.
    • Lay down the clean air filter on a towel until it's completely dry.
    • The filter will take about five to eight minutes to dry.
    • Do not place a wet filter back into the unit. Placing a damp filter in the unit can cause water damage to the air conditioner.
  5. How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: 手順 5、 3の画像 1 How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: 手順 5、 3の画像 2 How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: 手順 5、 3の画像 3
    • Replace the air filter between the front grille and evaporated coil.
    • Clip the front grille back to the unit and push the grille to align the sides with the clips.
終わりに
To reassemble the air conditioner, replug the A/C unit cord to the power outlet and turn it on.
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Angel R. Mariscal
メンバー登録日: 03/24/22
145 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team O-4, Briggs Spring 2022 CSU Los Angeles, Team O-4, Briggs Spring 2022人のメンバー
CSULA-BRIGGS-S22SOG4
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 50
今までの合計 1,218
